Is it OK to charge 2 plugins from the same GFCI?
Discussion in 'Prime Plug-in Charging' started by mistermojorizin, Oct 27, 2019.
  1. mistermojorizin
    mistermojorizin Active Member
    310
    136
    usa
    2019 Prius Prime
    My garage has several outlets, but only one is a GFCI (two plugs fit on that one). I'm thinking about getting a second Prime or other Plug-in vehicle. Would it be an issue to charge both cars from the two outlets on the same GFCI at the same time?
  2. john1701a
    john1701a Prius Guru
    12,760
    5,245
    57
    There's no issue with regard to sharing outlets on the same line; however, you may not have the capacity.
    12 amps is the regular draw setting. That works fine on an ordinary 15-amp line (since it allows for the necessary 20% safety buffer).
    To support 2 Prime at the same time, you need a 20-amp line. That requires reducing draw to the 8-amp setting for both vehicles. No big deal, it just extends the time... which is fine for overnight charging. Not all garages have 20-amp capacity though. Check the circuit to be sure.
    btw, only a single GFCI is needed on a line to provide protection operation.
    mistermojorizin likes this.
  3. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    If you find that your garage is served by multiple breakers, you can add a GFCi outlet for $20 in parts. If you only have one breaker I suggest one car at a time.
  4. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    It won't damage anything, if that's what you mean. But it will trip the circuit breaker, since they will draw more combined amps than the breaker (or the wires) will allow.
    noonm and mistermojorizin like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    And to clarify that a bit:
    If wired properly, one GFCI can protect other outlets on the same branch circuit too.
    In most cases, ALL the outlets in the garage are on the same branch circuit and they are all protected by one GFCI device, either in the breaker itself or in one of the outlets.
    If yours is wired that way, only one circuit for all of the outlets in the garage, then you would have to plug in your two vehicles one at a time or revise the wiring with a new circuit.
