Is it okay to mount EP422 in the front while keeping EP20 in the rear?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by txl146, Mar 19, 2015.
  1. txl146
    txl146 Member
    301
    NY
    Our Bridgestone EP20 tires still have plenty of tread but are showing cracks in the thread; as a result, I prefer to get tires replaced as soon as possible. Local tire shop has EP422 in stock and told me they don't have any EP20 in the warehouse. Although I can order through Tirerack, I wonder if I should just go ahead and get EP422 mounted. I believe both tires are very similar in specs.
    Any suggestion? Thanks.
    EP20:
    380BB 9/32" 17 lbs 833 rev/mile
    EP422:
    480BB 10/32" 19 lbs rev/mile (NA)
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    As long as you keep the newer tires in the rear and you keep track that the same tires are on the same axle when you do rotations, you're fine.
  3. Former Member 68813
    3,524
    981
    US
    no, the newer, better tires (EP422 in your case) should be in the back to ovoid oversteer and 180 degree type slide.
    every competent tire shop will refuse to put new tires in the front only.
    this is why regular tire rotations are recommended to avoid it.
  4. Mendel Leisk
    38,715
    OP, I've read through your post about 3 times, can't understand: why aren't you replacing all four tires at once?
  5. txl146
    txl146 Member
    301
    NY
    Oh - 2 rear EP20 tires were replaced last November. 2 front tires (EP20) are original tires that came on 2011 Prius (~51k miles).
  6. Mendel Leisk
    38,715
    Gotcha. I tend to stick with EP20 for replacement then. Last time I purchased those, through Costco, it was a similar story: asked for EP20, they said none were in stock but would EP422 be ok. I almost caved, but then called them back and asked if they could order in EP20. A week or so and they were in.
  7. KLNY
    KLNY New Member
    Buffalo, NY
    I just had a similar experience (not at Costco)....EP20's were ordered and EP422's substituted instead without my knowledge or agreement. I told them I want to stick with what worked for me and that was the EP20's. I had great luck with the EP20's that came on my 2011 Prius - ~56,000 miles on them. I could have gotten more, but since I switch to winter tires, the tread was low enough that it wasn't worth keeping them and paying to have them remounted and balanced since I would need new all season tires shortly thereafter. Apparently the EP20's are on "backorder", which I hope doesn't really mean that the tires have been rotting in a warehouse for years. I think the EP422 is a better rated tire, but for my particular driving habits, I'm sticking with what worked for me.
