Is it okay to skip minor (5k interval) service?
Discussion in 'Gen 4 Prius Main Forum' started by mudworm, Jan 12, 2020.
Thread Status:
Not open for further replies.
  1. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    I keep my cars for a long time, so I make sure to do ALL the scheduled services. I had a major service done (including extra services that the shop sold me) at 30k, and it now has passed 35k.
    Regarding engine oil, the Toyota recommendation says, "NOTE: If 0W-20 oil WAS NOT used at the last oil change, replace engine oil and oil filter." Well, 0W-20 was used at 30k according to record (I hope they are honest). So, no replacement.
    I'm going to Costco tomorrow to patch my leaky tire and have a rotation done.
    So, looks like I do not need a 5k interval minor service at all?
    It bugs me that I'm skipping a service, but I really don't see a need to take it to a shop. What do you guys suggest?
    BTW, how do I turn off the service reminder myself?
  2. Tyfly
    Tyfly Member
    65
    94
    I began skipping the 5k service at the dealership after the complimentary maintenance ended. I rotate my tires at discount for free and check the oil myself at the 5k interval.
    Resetting the maintenance reminder is found under “vehicle settings” on the multi-information display. Just below the driver assist options.
    mudworm likes this.
  3. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Thank you! Guess I should take a look at that oil. Did you buy your tires at discount before you can get free rotations?
    At 35k, my tires are still from the factory. Costco charges $21 for rotating, which is still better than a shop that charge $45 for just rotating tires and topping off oil.
  4. Tyfly
    Tyfly Member
    65
    94
    Discount tire, at least in my area of Texas, has free rotations even if you didn’t buy from them. They do charge for balancing though.
    mudworm likes this.
  5. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Good to know. It's America's Tire here in CA. I'll ask tomorrow. Always nice to save some $. :)
    Tyfly likes this.
  6. salyavin
    salyavin Junior Member
    39
    Littleton, Colorado
    I agree, I also skipped the 5k for many years now. As Tyfly said do rotate your tires, if you are using synthetic oil it really only needs to be changed every 10k but make sure it is not getting low or anything.
    mudworm and Tyfly like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Hmmm. My dentist says you only need to brush the teeth you want to keep. My corollary is that you only need to check the oil on engines you want to keep.
    I normally rotate tires for free at home. Same with changing oil but it ain't free. I got my current set of tires at Toyota and they offer free rotations, so I take advantage of that on my car. It's usually quicker to rotate them myself, but that gives me an excuse to prowl the lot to see if maybe a Prime or a Rav4 hybrid snuck into the lot under the distributor's radar. So far, two Primes and zero hybrid Rav4s that I know of.
    Back to the original question, all that's involved in the 5k in-between schedule (assuming synthetic oil) is tire rotation, fluid levels, brake wear, wiper blades, and driver's floor mat. Other than tire rotation and brake wear, I look at that stuff every few weeks or sooner. Until they start getting close, the brakes don't need checking every 5k. They and tires can be stretched to 10k, but the tires will wear a little faster and the brakes will be getting riskier the older they get.
    dig4dirt and mudworm like this.
  8. Mendel Leisk
    41,901
    There are two levels of brake inspection: the visual inspection every 5K (which is kinda overkill), and Toyota "alludes" to a more in-depth inspection every 30K miles (or 3 years, whichever comes first). Their instruction for the latter is very vague though. I would recommend to pull the calipers off the rotors, clean and relube the caliper slide pins, clean and relube the pads/shims and caliper contact points. Also check pad thickness and record. Ocassionally a rotor thickness and runout check is good, especially if you're noticing any troubles.
    jerrymildred and dig4dirt like this.
  9. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    One thing I paid for at the 30k service was "brake cleaning" service for $104 extra. I sure hope they did a good job checking and cleaning the rotors.
  10. bisco
    52,390
    more importantly, did they lube the caliper slide pins
    dig4dirt likes this.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The tire rotation IS the 5K service.
    You can reset the maintenance reminder yourself.
    The procedure is in your owners manual; it varies a bit depending on model.
  12. Mendel Leisk
    41,901
    Uh wait a sec, there's also the driver's floor mat check, can't forget that... :rolleyes:
    (There's no mention of that in the Canadian schedule, we're all hell-bound...)
    kithmo, jerrymildred and dig4dirt like this.
  13. mudworm
    mudworm Member
    84
    99
    SF Bay Area
    2018 Prius
    Understood! I'll get the tires rotated at a tire center, and don't think they'll deal with the service reminder, so I don't call it one. But you are right.
    I really should get in the habit of checking the oil as well, especially when I don't take it in for the 5k interval.
    mikey_t and Tyfly like this.
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Might be regional, but our local Walmart tire center includes free rotation and re-balancing on all tires purchased there. However, I usually do a rotation at the time of winter tire change over myself.
    Tyfly likes this.
  15. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    I'm surprised nobody has yet recommended changing the oil and filter at (or before) 5,000 miles, yet. The old school part of me will be pushing to change my factory fill by 5k, for sure. (Of course, this change wouldn't be covered under Toyota Care)
    #15 pjksr02, Jan 12, 2020
    Mambo Dave likes this.
  16. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Truly "old school". I've done a ton of research on oil life in my life (Bob Is The Oil Guy). I started 10k oil changes (Mobil 1 fully synthetic) WAY back in 1987, with my first Audi. I've put several hundred thousand miles on VWs. Audis, Hondas, Toyotas, running almost all my cars to 130-150k miles. NEVER an oil related issue, nor have ANY of them burned any oil.
    I send oil samples to Blackstone every 30-40k miles, and in every case, they've recommended I could stretch to 12k, even 15k changes.
    Hybrids ICEngines work much less than a normal engine. With my Ford CMax, Blackstone recommended I could go to 15k miles, with PLENTY of oil life remaining.
    Curiously, every Toyota dealership I've been to in the FortWorth, Texas area puts a sticker on my windshield, recommending a 5k oil change. However, when I ask the service mgr at each dealership, they quietly tell me Toyota's recommendation for every car is 10k miles.
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I agree, I've seen oil test results extend change intervals considerably. I do mine according to TOYOTA's specification while it's under warranty. Plus - I tend to move my cars on after 3-4 years, and near-new car buyers expect to see all services stamped in the Service Book.
    Engines and oils have improved exponentially over the years since the first car I was involved with (a '49 Austin with SAE30 oil) - first change at 500 miles then:
    I think Dad did it more like every 3 months, but it was well less than 2000 miles, but we'd always have to add some between changes.
    upload_2020-1-13_15-0-8.png .
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    I don't make a visit to any service center JUST to rotate the tires.
    I do both oil change and tires about 7K miles.
  19. pianewman
    264
    183
    2018 Prius
    According to info (BobTheOilGuy) and other sources, a too-frequent oil change has the potential to ADD wear to the engine, not decrease it.
    The way I've seen it described is as follows:
    1) The first "x" minutes/hours of oil life in the crankcase, the detergents are working as...detergent...therefore, the "protection" of the previous oil is being removed. This period offers less protection for the moving parts.
    2) After the detergent is spent (no longer chemically active), the chemistry of the oil goes into "protection" mode, which lasts until the chemical "oil life extenders" are no longer active. This time period can be quite lengthy, and a company like Blackstone can tell you, with their analysis, how much protection remains in the oil.
    The reality is TOO frequent (less than 10k miles, IMHO [until I send a sample to Blackstone]) oil changes is possibly detrimental, wasteful...and expensive.
    kithmo and Tyfly like this.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    And I think your "reality" is not.
    Even if you believe that the makers of automotive oil put ingredients in there that "fight" each other (I don't believe that at all).......your ideal interval is WAY too long.
    "Detergents" can be engineered to react with different things in different ways.
    What exactly makes you think that they would be stupid enough to put in one additive that defeats some of the others ???
    I mean exactly as in "please quote an authoritative source", not just some self appointed Internet expert.
Thread Status:
