Is It Possible To Add Headlight On/Off Feature On An LE?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Oct 1, 2025.
  1. VelvetFoot
    VelvetFoot Member
    211
    New York State
    2026 Prius
    (I don't have the car yet.)
    It seems the LE version does not turn on its headlights when it gets dark.
    Is it possible to add this option, perhaps via the OBDC port and an app?
    #1 VelvetFoot, Oct 1, 2025
  2. Winston Smith
    Winston Smith Active Member
    304
    218
    OH
    2024 Prius
    LE AWD-e
    What is the DL version?
  3. ChapmanF
    17,826
    In gen 3 it involved studying the wiring diagram differences between the versions with and without, then adding some wires and changing a switch.
    After the first person figures it out, others can just follow the post. I don't know if the first person has done it for gen 5 yet.
    VelvetFoot likes this.
  4. VelvetFoot
    VelvetFoot Member
    211
    New York State
    2026 Prius
    Thanks. I forgot about the switch. It's on a steering wheel stalk, right? Might not be easy or cheap just to do that.
    edit: I found the thread, from 2009!
    #4 VelvetFoot, Oct 1, 2025
  5. ChapmanF
    17,826
    When I did it on my gen 3 I found a Lexus stalk that fit perfectly and had both a headlight AUTO position and a fog light switch, for $40 at a recycler.
  6. VelvetFoot
    VelvetFoot Member
    211
    New York State
    2026 Prius
    At this point there may be some higher end late model Prius-es at the junkyard. :)
  7. VelvetFoot
    VelvetFoot Member
    211
    New York State
    2026 Prius
    Fixed it, thanks.
    I have a lot of acronyms bouncing around in my head, I guess. :)
  8. Hammersmith
    Hammersmith Senior Member
    2,208
    2,216
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    There absolutely are. I've bought parts off of one, and trying to get more off another. They aren't plentiful, but they're out there. Use http://www.Car-Part.com to find them.
    GcinFl and VelvetFoot like this.
  9. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
    If you can't figure it out there is a viable-ish workaround.
    Keep the headlights on at all times and turn the headlight timer to 0 from the headunit. This will run your low beams at all times, turn them off automatically when you turn off the car, and stop the annoying buzzer from going off if you open the door without turning the headlight off.
    Downside is your miss out on your head light staying in for a bit after you leave your car.
  10. Gokhan
    Gokhan Senior Member
    5,963
    2,356
    Paramount CA
    I know that sucks. That is the only safety feature the LE/SE are missing. Never use the DRL-off position in case you forget to turn on the headlights.
  11. VelvetFoot
    VelvetFoot Member
    211
    New York State
    2026 Prius
    My MINI has it. It also has cool looking DRLs, like the Prius. Be a shame to give them up.
    Gokhan likes this.
