Is it possible to charge hybrid battery via an outlet while using the AC?
Discussion in 'Prius c Main Forum' started by RichV, Jul 23, 2022.
  1. RichV
    RichV Junior Member
    Decatur TN
    Possibly looking to car camp overnight and would have access to an outlet. Is it possible to charge the car with a prolong or similar charger while the car is running? Obviously not looking to drive the unit while plugged in, only looking to have the AC running if its a brutally warm night down here in the southern USA. My thinking is that this way the conventional engine wouldnt need to ever turn on to replenish the hybrid battery.
    49,371
    unfortunately, no.
    everyone just leaves it in ready. annoying when the engine kicks on, but no harm to the car, that's what it was designed for.
  3. Rmay635703
    Rmay635703 Senior Member
    2,591
    1,608
    Somewhere in Wisconsin
    2013 Chevy Volt
  4. Danny13pruisc3
    173
    27
    maryland
    I just googled camping air conditioner.. you might find something to your liking.
  5. Leadfoot J. McCoalroller
    7,135
    6,682
    Pennsylvania
    2018 Prius c
    Never say never... but there is not a quick, convenient, easy or inexpensive way to do this.
    Part of the problem is that a Prius air conditioner can use more power than a household outlet can deliver.
    It would cost less to adapt an ordinary air conditioner appliance.
  6. ChapmanF
    15,435
    The variable-power A/C compressor can run at anywhere from about 250 watts to around 2500 watts depending on how much cooling is needed. From the roughly 202-volt battery, that's from around an amp and a quarter, up to around thirteen amps. (Plus the rest of the car in READY mode, which will draw a couple of amps or more.)
    A charger like a Prolong, made for grid charging, normally supplies a lower current than that (if I'm not mistaken; I haven't got one), so even if you could rig it to operate in parallel with the car in READY, it wouldn't be supplying enough juice to keep up.
    You might, instead, try to rig some larger, higher-current (probably more expensive) 220 VDCish supply. Say you found one that supplied less than ten amps. If you got it working the way you want, it could keep the engine off forever when the total draw is within that budget, and it would at least extend the time between engine starts when the load is higher than that.
    You'd just be kind of on your own to get it designed and working, and see how much it confuses the car's battery management.
