Is it possible to drive on battery power alone for short distance?
Discussion in 'Gen 3 Prius Main Forum' started by wwk68, Nov 8, 2019.
  1. wwk68
    wwk68 New Member
    Kansas
    I was checking to see if it's possible to go 2-3 miles bypassing the gas engine. My wife wrecked the car and the radiator is toast and all fluid has leaked out. I need to get it home and was curious if the EV mode is a possibility for this situation. I couldn't find an answer in the owner's guide. Any help appreciated.
    2010 Prius, body model V
  2. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    No because not all EV only conditions are met. Even if car did met conditions, it’s Not possible to even drive more than 1.5 mi (flat road) on EV either and ICE will fire up after 40 secs
    RMB likes this.
  3. wwk68
    wwk68 New Member
    Kansas
    Okay, I will have it towed. Thanks.
    Mendel Leisk and bisco like this.
    48,987
    welcome to priuschat!
    make sure they flat bed it.
  5. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Have wife towed also, youre due for a new one.
    PriusGuy32 likes this.
  6. Mendel Leisk
    38,247
    I don't think that's necessary. The rear wheels can be on the ground, just ensure the parking brake is off . For sure the front should be off the ground.
