is it possible to swap Prius v 2013 five led headlight to halogen assembly
Discussion in 'Prius v Accessories and Modifications' started by randyhawk, Jan 25, 2024.
  1. randyhawk
    randyhawk Junior Member
    winnipeg canada
    I bought 2013 Prius v five from united states which has factory led headlight, is there any way i can change the headlight to halogens as they are in other models, is wire harness same ?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    My understanding is you would get codes because your system has special headlight level controls which would be lost. Otherwise it could be done as long as you also swapped connectors and did your wire splicing.
    But most people get tired of the low beam halogens burning out. And the somewhat ineffective halogen low beams. So many end up replacing the lower cost halogen bulbs with four relatively expensive aftermarket led equivalents.
    In this diagram both are shown with *1 being oem led low beams and *2 representing oem halogen on both beams.
    #2 rjparker, Jan 26, 2024
  3. Mendel Leisk
    38,649
    For what reason? The stock LED’s are supposedly very reliable, and the premium option. Sounds like a can of worms.
    Do have a look at the LED levelling gizmo, it’s a small arm linkage on the trailing side of the solid rear axle. In salty/wet conditions it can seize up. There should be enough clearance that you can reach it without need to raise car. I’d just disconnect it at one end, move the joints back and forth (gently).
    our ‘10 touring has them, fwiw.
    #3 Mendel Leisk, Jan 26, 2024
    Air_Boss likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    1,441
    789
    SacTown, Ca
    Be careful performing a swap like that. Look at the wire and relay specs. since halogen lamps draw sugnificantly more power than LED bulbs along with the higher heat output affecting your plastic headlamp housing.
  5. Tombukt2
    Tombukt2 Senior Member
    8,917
    1,553
    Durham NC
    You are barking up a tree that the fireman won't even get you out of. Don't even fool with this you'll have way more trouble than you want to deal with I mean you're not going to get Cibe Z beams or the equal to those today in this model car easily Not saying you can't get something done but boy I'd have to be living in the car at night to be even considering this at this point in the game maybe add-on some lights in the grill or something that could be much easier done that's nothing to alter a bumper cover You can sit there and do it on your computer in various and sundry drawing software until you get it right and get the hole saw out. The plastic of the bumper cover is easily glued upon and attached to with various and sundry solvents that will hold very well so you can add a bucket behind the hole you put in the bumper cover and all of that stuff You can carry it to the next level easily but easily have something to work with that's not going to affect the rest of the car and computer systems for whatever reason flip a switch and you got instantaneous daylight.
