Is it possible to temporarily reset odometer in Prius 2010?
Discussion in 'Gen 3 Prius Main Forum' started by Rectifier, Apr 14, 2010.
  1. Rectifier
    Rectifier Junior Member
    Massachussetts
    May be somebody can help. Is it possible to reset odometer temporarily to zero by any manipulation, let's say disconnecting battery's negative terminal, or positive or doing something else?
    I believe eventually odometer would return to previous reading but could it be done at all?
    I thought that nobody should be able to change odometer reading no matter what, but I could have sworn that I saw on odometer low reading like couple of hundred miles and later on it became few thousands. My impression was that somebody manipulated odometer and later on it returned to normal reading.
    Is it possible? :(
  2. smartalec89
    smartalec89 The Official Alaskan
    133
    anchorage, alaska
    In the legality of this question I will tell you "no"..... but I do know it can be done and its not by disconnecting the battery. All the data is stored on memory and it can be bypassed. I don't suggest trying it you could mess up your car completely.
  3. avian
    avian New Member
    33
    Houston, TX
    You bought a used prius and you think the Odo changed while driving it? Are you sure you didn't confuse the Trip A, Trip B, Miles to Empty with the Odometer?
    There is no way a 'tampered' odometer would go back to what it should be, seems like it would be a permanent thing.
  4. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    What you probably saw is this: Whenever you press the "Trip" button on the steering wheel, the ODO display switches from showing the odometer reading to the trip odometer to "miles until empty."
  5. creativeguy
    creativeguy Member
    301
    17
    CA
    If this was possible, I think Congress would drag Mr. Toyoda back to D.C. to do some 'splaining. ;)
  6. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    Hmmm...what exactly is your address? I will send an advisor (with cuffs and a taser) your way to help you out.
