Is it safe to drive an 07 Prius with P0AA6 code (Voltage Isolation Fault) due to a bad transmission?
Discussion in 'Gen 2 Prius Main Forum' started by Jesse Goldman, Jul 10, 2021.
  1. Jesse Goldman
    Jesse Goldman Junior Member
    16
    Springfield MA
    For about a week I have been getting p0AA6 code from my OBD2 , took it to the Toyota Dealership and they also confirmed p0AA6 code, but did not give me a subcode other than 526 for some reason and I already took the car back. They said it needs a new Transaxle. On the printed report they gave me it says:
    "VERIFIED CUSTOMERS CONCERN RETRIEVED CODE P0AA6 WITH THE DETAIL CODE 526 FOUND TSB PERTAINING TO INTERNAL TRANSAXLE FAILURE OF THE VOLTAGE SYSTEM RAN TEST PLAN VERIFIED INTERNAL FAILURE RECOMMENDED TO START WITH KNOWN FAILURE OF TRANSAXLE AND RECONFIRM NORMAL OPERATION"
    Anyway is it safe to drive it for now, if the Transmission is really the cause of the issue? I have an appointment with a few other mechanics next week to get second opinions and to see if someone can install a used Transaxle. I'm just driving to work which is down the street and maybe around town and to the mechanics, nowhere too far. But I heard a high voltage leak can be dangerous?
  2. ChapmanF
    15,572
    If this is a new thread about the same issue you raised here, it remains true that "due to a bad transmission" in your thread title is premature until a second INF code shows up (or equivalent further diagnosis is done).
    Once the second subcode shows up, depending on what it is, then you'll know whether it's "due to transaxle failure" or "due to battery failure" or "due to inverter failure" or "due to air conditioner failure" or "due to wiring failure", and from there it will be clearer what repair is needed.
    The car will generally allow you to do some driving, though you may have to reset the code to get it started again. Safe? There's judgment involved. Good idea to get the problem taken care of soon.
    On the other hand, jumping into a repair, before knowing what to repair, might be too soon.
    drone13 likes this.
  3. Jesse Goldman
    16
    Springfield MA
    Thanks for the reply. Yes this thread is about the same issue and i posted this yesterday, but I guess it only now got approved because i'm a new user. And yes I have been clearing the codes with an OBD2 to keep it driving. Yeah I didnt know that it could take a while for the second detail code to come up, now I feel i kinda wasted my $135 at the dealer since it's still not for sure the transmission. I wonder if they would let me take it in again to get checked for the second code without charging me again, ill have to call and ask. I have an appointment with another mechanic next week to get a second opinion, hopefully they also have the equipment to check for subcodes and can confirm whether or not it's the transmission, since i'd rather not take it back to the dealership.
    #3 Jesse Goldman, Jul 10, 2021
  4. ChapmanF
    15,572
    If you have a way of clearing codes, you can also look for old threads on a way you can do some location of the leak yourself through a sequence of steps:
    If the code returns after some time with the car only ON, the leak is in the battery.
    If the code doesn't return until you make the car READY, the leak is in the frame wire or inverter.
    If the code doesn't return until you shift out of Park, the leak is in the transaxle.
    If the code doesn't return until you turn on A/C, the leak is in the A/C.
    Those are more or less the same steps the ECU is doing for you when it has already logged the 526 subcode and is deciding what second subcode to log.
    There are some OBD2 readers (other than Techstream) that also can read the subcodes, or at least can be taught to read them. There should be some Gen 2 Prius PID definitions findable on the net that include the locations of the subcodes.
    Repeatedly clearing the codes to keep driving might be part of why the dealer only saw the 526. Clearing the codes of course takes things back to square one, and then the car has to re-detect first that there is a leak (and set the 526), and then in a later drive cycle see that it has set 526 and do the extra work to set the second code.
    prius8654 likes this.
  5. Jesse Goldman
    16
    Springfield MA
    Interesting! The code seems to pop up kinda randomly though. Usually it pops up whole driving I would say. But sometimes I'll drive error free for a day, then turn it off. Then the next day I turn it on and it has the code. My sister said she got it once immediately after putting on her turn signal while driving. I don't think the A/C has ever triggered it and I don't think I've gotten it when the car was only ON and not in Ready mode. So am I basically wasting my time taking it to mechanics without having that second subcode? Will any mechanic be able to pinpoint the issue without it or no?
  6. Jesse Goldman
    16
    Springfield MA
    Also, if we assume it is the Transaxle that's failing. How bad is it to keep driving the car with a bad Transaxle? Could other rpartd be damaged int he process or is it fine? I think I read somewhere it could damage the inverter if you drive with a bad Transaxle?
  7. ChapmanF
    15,572
    I don't know that I've seen a specific report of that, but it stands to reason that it could be possible.
    If you never manage to catch it with that second subcode, then your mechanic can just follow through the whole "P0AA6 with only 526" troubleshooting section of the repair manual, which will involve taking a bunch of things apart and testing them with a megger. Here, "any mechanic" might mean "any mechanic comfortable with hybrids", because others might just say "high voltage system? megger? nope, not me."
    Even when the second subcode is available, a good mechanic will still work through the troubleshooting steps for that code, which will still involve some megger testing to confirm what's going on. What's good about the second code is that it lets you focus that testing on the identified one out of like five possible areas, so it saves you 80% of the troubleshooting work.
  8. sammynaz
    sammynaz Junior Member
    Walnut CA
    I’m dealing with a similar error code now !
    Please let me know when you can read my message here so I can send more details if ok
  9. ChapmanF
    15,572
    This code is about high-voltage leakage somewhere in the car (the high-voltage system is supposed to be fully isolated from all the rest of the car). It does not have to be in the transmission (though it can be). It does not have to be in the battery (though it can be).
    The best way to troubleshoot a P0AA6 is to use a scan tool that will also show you the detail code, 611, 612, 613, or 614, telling you where in the car to look for the leakage. When you search threads here about P0AA6, you will find a lot of them include a diagram with red, pink. blue, and green areas showing where in the car to be looking, for each of those different detail codes.
    For example, the frame wire is part of the 614 area, so if you had 614, the frame wire would be one thing for you to check, and if you had one of the other codes, then it wouldn't.
    If you can't get your hands on a scan tool that shows the detail codes, and can't get your car to someone who has one, you can also just start from the very top of the troubleshooting steps in the repair manual and go down each branch; it just takes longer that way. Some of the steps call for an instrument called a megohmmeter or megger. You will also find multiple threads here describing that (including important notes about safety).
    Happy troubleshooting!
