Is it save to drive with P420 Cat Converter Code
Discussion in 'Gen 2 Prius Main Forum' started by Victorio Mo, Feb 23, 2018.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    124
    31
    Folsom, California
    all I just got this 420 code, even I don't smoke marijuana ). I understand that it's not super critical, so I can drive it, till I will need hit my next smoke check, am I right ?
    Thanks all
    Dai
    Prius 2008, 195K
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Maybe that was a joke when they decided the code numbers :D
    If you drive long enough with that code theoretically you could get blocked catalytic converter. But if you have to check it once a year this probably won’t be a problem.
    Other problem is that driving with that code your check engine light will be on and then you don’t know if there are other problems (that would only light up the check engine light) until you read the codes.
    How much oil your Prius consumes? This could be the reason catalytic converter failed.
