Is it Time to Change the 12V Battery ?
Discussion in 'Gen 2 Prius Technical Discussion' started by wirelessjava, May 22, 2023.
  1. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    Hello Bisco and Prius Friends
    I did the 12V Battery Check and my battery is at 11.4 or 11.6 not the nomral 12.2 or 12.6 I bought the battery from AAA I have been getting the prius Gen 2 reset dance ( Basically it is like someone pulled the plug on and off of your 12V prius )
    Should I change the battery? I do not know of AAA has a warranty on my battery?
    ---wire
    51,154
    it sounds like it. how old is it, maybe just needs a good charge
  3. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Sounds like you should check the connections at the battery and also where the negative cable connects to the car.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    How old is your battery ?
    How often is the car driven.....and how far ??
    And under what conditions are you measuring the voltage and with what kind of device ??
    The connection at both ends of the main cables needs to be checked, as well as the battery itself tested AFTER
    being fully charged with an external device.
    THEN the charging voltage needs to be checked with the car running (READY mode).
  5. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    I think my battery is 2.5 years old and I have not been driving it many miles but only 5 miles per day.
    ==wire
  6. bisco
    51,154
    take it to auto zone for a charge and load test. maybe you need a maintainer to keep it charged
  7. sam spade 2
    7,035
    2,799
    2017 Prius c
    That might not be enough to keep it charged.
    To repeat:
  8. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    AAA battery sucks.... Although not technically a scam .. but they do purposely have SH*T batteries. Find a better replacement.
  9. bisco
    51,154
    i'd be surprised, but who knows? any warranty?
  10. wirelessjava
    wirelessjava Member
    103
    Union City, CA
    Wazzup Bisco...
    Triple A batteries are crap. I need to get a battery with a 7 year warranty. Any recommendations?
  11. bisco
    51,154
    no such thing. duracell may be 4 years. oem is 8 years iirs, but pro rata after 2 years. i went oem cause my first one lasted 7 years
    wirelessjava likes this.
  12. sam spade 2
    7,035
    2,799
    2017 Prius c
    AAA likely does not use exactly the same battery over time nor from one state to the next.
    SO.....ALL of the ones they supply are not likely to be "crap".
    Then.....the length of the warranty bears NO direct relationship to the quality of a battery.
    It is mostly a marketing gimmick.
    AND the longer warranties are almost always "pro-rated" after a couple of years and
    are based on the "list price". So if it fails after 4 years, the warranty price might actually
    end up being higher than the "off the shelf" current price for the same battery.
  13. Mendel Leisk
    40,584
    AAA very likely supplied you with a quality battery; your expectations are the issue here: if you’re low usage and pay no attention to it, any battery is going to die in short order.
    See post #6. If you’re low usage you HAVE to get cagey with batteries. They will die if you’re low/sporadic use, and don’t take measures. Read up, get a smart charger (and use it), maybe an electronic load tester too so you will know where it’s at.
    #13 Mendel Leisk, Jun 1, 2023
  14. rjparker
    rjparker Tu Humilde Sirviente
    9,596
    5,893
    Texas Hill Country
    You have to understand the car draws current from the 12v battery all the time. But it only charges it while you are using the car.
    Second, the battery may have been low when you got it or there may be something drawing more off state current than normal. This can be checked. If an excessive parasitic draw exists, a new battery will exhibit the same behavior.
    Finally a load test can verify the condition of your battery and it is often free at auto supplies. A parasitic draw test is easy for a mechanic but will cost a little.
    #14 rjparker, Jun 1, 2023
  15. Prius DIY nut
    Prius DIY nut Member
    82
    40
    Ontario, Canada
    I have more than 11 years old original battery in my 2012 Prius. I asked my local Canadian Tire store to load test it and they said it is still good. Anyone else is using their old original battery of 11+ years with no issues, is it ok to continue using it or better replace with a new one?
    If you curious why I am asking, it is because I started checking the auxiliary battery after ABS unit pump faulting concerns, I got long (20sec) pump run while opening driver door first time in a day. After charging the battery the run time went down to almost normal, about 7-10 sec.
  16. dolj
    dolj Senior Member
    8,217
    4,187
    This is a Gen 2 thread and you're tagging onto it asking for information about a Gen 3. The design in this area is different between these two generations. It would be better to find a thread in one of the Gen 3 forums or even start your own thread over there so you get information relevant to your generation of Prius.
    Prius DIY nut likes this.
