Is it too late to change trans-axle fluid hitting 300,000 miles?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Adan x, Apr 13, 2021.
  1. Adan x
    Adan x New Member
    San bernardino
    So had the car for many years. It never occurred to me to change the fluid as the dealer said its lifetime. I just realized after many years that they have probably lied to me. I am worried if I change it the transmission fluid it will go out. I know this happens all the time to regular cars. I do plan on getting a used engine later. Can I buy a used transmission for this car as well to be safe? Also should I replace the generator as well??? I am new to this form and getting to know the Prius better.
  2. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    There's no way for a fluid change to cause the transmission to fail. It's simply gears and motors bathed in oil, there are no small shift passages, torque converter, etc. to fail when you change the fluid. It's never too late.
    Raytheeagle likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Never too late. Just a simple dump and fill, like the engine oil. Loosen the fill bolt first before draining the old fluid, and you'll need 3.9 qts of ATF WS (or equivalent). Be sure to post up some nasty pictures of the filthy old ATF fluid, as some members like that.
    How many years?
    This happens quite often.
    No need to worry, your existing engine will likely fail sooner than this transmission.
    Sounds like a plan, and it should be easier to replace the engine transmission assembly as a single unit.
    MG1 and MG2 are part of the transmission, or were you thinking of the Inverter?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There are reasons (or excuses) not to change the ATF in 'normal' automatices: Bands, Clutches and valve body hydraulic logic. The Prius has none of that, so they can't go bad. You just do a drain and fill with ATF WS as there is also no torque converter.
    If you listen from 4:50 He explains why you might not want to change the fluid. Your Prius has none of those parts.
    Aaron Vitolins and Raytheeagle like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Make sure you open the fill hole on the side first. That bolt is really really tight.
    Biggest breaker bar you can find.
    Takes exactly 4 quarts WS.
    PS: Dont bother posting a picture of the fluid it will be black. We have seen many of those.
    Good luck.
    #5 edthefox5, Apr 13, 2021
  6. ETC(SS)
    6,554
    Asked and Answered.
    Concur with all.....
    As stated the Prius does not have a "transmission" so you may disregard any and all advice that suggests that changing the fluid after 300k would be a bad idea.
    You have a G2.
    They are what we in the phone biz call...."manufacturer discontinued."
    This means that the newest transaxle (power split device) you can buy will already be over 12 years old, so I would treat it like everything else on the car and just wait for it to start giving you problems before buying a replacement.
    The transaxle has stator windings inside (wires with a thin insulator coating) that can go bad if you use anything other than an approved transmission [sic] fluid. Most of them are "probably" OK to use....but I'd stick with the house blend for this job (Toyota ATF WS) instead of trying be cute and buying something in the snake-oil section of your local parts house.
    Good Luck!
  7. ChapmanF
    15,571
    'Transmission' being the thing that transm ... er ... gets the power from the engine producing it to the axles needing it, there's really no reason to play "[sic]" games when talking about it.
    So it's a transmission that's not built the same way as the transmission in an Edsel. That's totally allowed.
  8. fuzzy1
    10,167
    I think this is one of the few times that it wasn't the dealer who lied. They were just repeating the official word from above.
