Is it worth paying dealership for an engine flush, inverter flush, transmission flush?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by onlineorange, Jul 12, 2021.
  1. onlineorange
    onlineorange New Member
    boise idaho
    Costs:
    • radiator flush and inverter flush, using machine to push fluid the fluid through (half the cost is labor): $144
    • transmission flush $259
    $35 for each of the inverter/engine coolant being replaced sounds not much more than an oil change, so that sounds reasonable.
    But the tranny fluid replacement sounds high. I read on the gen 3 forums that flush isnt used, but not sure about gen 2, and I assume its just a nice way for dealership to overcharge.
  2. onlineorange
    boise idaho
    I made this a separate thread from my last, but cant really edit the old one, nor delete this one. I love tech.
  3. PriusCamper
    PriusCamper Senior Member
    10,898
    4,418
    Pacific Northwest, USA
    It was a long time ago when radiators were a source of corrion, leaks and failures... Times have changed... This maintenance is not needed.
    As for trans flush I charge for 90 minutes or $60 plus cost of fluid. So if you want to save some dollars and have some battery diagnostics done as well and you plan to drive out to Seattle area at some point message me.
    ifixwashers likes this.
    48,946
    no, how many miles on her?
  5. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    1st off; taking it to the dealership --- u've heard of the other word for that place that starts with the letter 'S' ... there is a reason ..
    now , that is not everydealership but , unless you have direct otherwise experience, it is not a good place to take your car ,.. there is a reason why there is free coffee, popcorn and a theatre room .... like the dentist office, lulling you to a relaxed state of happiness is their
    goal ...
