Is Keeping A Flash Drive Plugged In Okay For Battery?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Dec 4, 2025 at 11:35 AM.
  1. VelvetFoot
    VelvetFoot Active Member
    632
    224
    New York State
    2026 Prius
    Is there more parasitic current usage as a result?
  2. hill
    8,802
    If there is, it's miniscule at best.
    VelvetFoot likes this.
  3. VelvetFoot
    632
    224
    New York State
    2026 Prius
    I thought I read a post where the idea was that something plugged into the data port or even the charging ports could do something or other to keep something or other from sleeping totally. That was my takeaway. :)
  4. BiomedO1
    BiomedO1 Senior Member
    3,575
    1,854
    SacTown, Ca
    If the port your plugged into powers-off when you turn-off the car, it shouldn't matter. Stuff plugged into the OBD2 port will keep things awake because there's a wire running directly to the battery. The infotainment system has a slight draw to keep the clock and station programming active.
    You can test the USB port by plugging something like your phone into it, it should start charging - turn-off the ignition to see if the port dies - no power no system drain.
  5. fuzzy1
    10,437
    On the 2012 that I drove for a dozen years, it was perfectly fine for the car and battery, but eventually killed the flash drive.
    I'm fairly sure the flash's damage accumulated while the car's ignition was turned on, not off.
    BiomedO1 likes this.
  6. BiomedO1
    3,575
    1,854
    SacTown, Ca
    ^ Yep constantly electronically hammering away at it, will eventually kill it. Add to that the internal car temperature exstreams. Luckily, flash drives are cheap an plentiful, so hopefully you've got several backups waiting in the wings......
