Is Li-Ion Assembly from Gen 3 to Gen 2 possible? good! Any thoughts?
Discussion in 'Gen 2 Prius Technical Discussion' started by LukUsc, May 23, 2020.
  1. LukUsc
    LukUsc Member
    69
    26
    Poland
    Is there a thread somewhere about li-ion assembly from 3-gen to 2-gen?
    Is it real at all?
    I'm also trying to find a topic about expanding the capacity / installing an extra battery. Can You help me indicate where to look for it? Thx :)
  2. dolj
    dolj Senior Member
    7,639
    3,854
    Wellington, New Zealand
    You are probably misunderstanding (maybe due to poor translation) or remembering incorrectly.
    It is not possible to transplant Gen 4 Li-Ion modules into a Gen 2.
    Try searching and reading up in the Prius PHEV Plug-In Modifications forum.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I think some of the addon plugin kits for Gen 3 used Li-Ion. Those companies and their products died out after the PiP was introduced. They had a Li-Ion specific charging circuit though.
  4. LukUsc
    LukUsc Member
    69
    26
    Poland
    What is PiP? :)
  5. LukUsc
    LukUsc Member
    69
    26
    Poland
    Maybe I gave the wrong model type 3th (in Europe we didn't have so many of them :))
    But I meant the packet 207.2 volts for lithium vs 201.6 volts for nickel-metal. (Looking very similar)
    From what I read, Toyota offered them interchangeably in one of the models.
    Hence the idea of trying to replace the HV battery with a li-ion.
    I understand that there is no option to replace Ni-Mh with li-ion in this way?
    Of course, I mean replacing the entire HV battery with BMS, etc. Not just individual modules.
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Plug in Prius. Gen 1 Prius Plug-in 2012-2015 | PriusChat
    I can't figure where you might have seen something like that where someone didn't correct the misinformation.
    Toyota does offer both types of batteries in the 4th generation, but you get whatever technology your particular model comes with. There is no option to, for example, get a 2020 trim 4 with a NiMH battery. Only the AWDe gets that. And there is no way to get an AWDe with Li-Ion. It ONLY comes with NiMH.
    Prodigyplace likes this.
  7. Prodigyplace
    11,696
    11,318
    Central Virginia
    The original Plugin Prius, replaced by the Prius Prime or Prius PHV in Gen 4.
    LukUsc likes this.
  8. Prodigyplace
    11,696
    11,318
    Central Virginia
    But it is possible to transplant Gen 4 NiMH modules into a Gen 2 or 3. Toyota claims they used a higher grade nickel in Gen 4 modules.
    jerrymildred and LukUsc like this.
  9. LukUsc
    LukUsc Member
    69
    26
    Poland
    Plug in Prius .... I wouldn't think of that
  10. jerrymildred
    11,508
    14,110
    Tampa, FL
    Toyota's literature calls it "Prius Plug-in Hybrid." But around here we tend to simplify it to PiP. Economy of syllables.
    Plug in Prius
    Is there a more accurate abbreviation? :LOL:
    LukUsc and Prodigyplace like this.
  11. Prodigyplace
    11,696
    11,318
    Central Virginia
    For the Prime I recommend ugly. ;). Not butt ugly but the other end.
