Is Mahle Who Manufactures Toyota Head Gaskets?
Discussion in 'Gen 3 Prius Technical Discussion' started by James Finch, Aug 1, 2023.
  1. James Finch
    James Finch Junior Member
    69
    Whitehall, Mi
    So this video from Riviera Auto, a former Toyota Tech, notes that Mahle is Toyota's head gasket manufacturer? At least I think was in this video and is at least noted in the comment replying to @eddiepadilla1078 where stated:
    "The benefits to using the Mahle Kit is I found out that Mahle is the company who actually makes the factory head gaskets for toyota you can get them cheaper."
    Anyone else aware of and know if is true or who manufacturers the head gasket and/or kit if otherwise?
  2. James Finch
    69
    Whitehall, Mi
    Referencing this Toyota Head Gasket Kit and Head Gasket post here: New Headgasket Video (Car Care Nut) | PriusChat
    Also referencing another prius group therapy session, I needed, that has info regarding the EGR Valve. Can EGR Valve Part # 25620-37110 Swap With 25620-37120 Installed Already In 2013? | PriusChat
    This looks like the kit I want to at least reference for ideal parts, especially if not removing the manifold from the head and only disconnecting the manifold from the catalytic converter when pulling. Engine Gasket Set - Toyota (04111-37316), Other Names: Gasket Kit Engine O
    Anyone know where these kits are listed itemized with each part that comes with the kit?
    #2 James Finch, Aug 1, 2023
  3. Paladain55
    Paladain55 Active Member
    378
    143
    The South
    I would be careful with assumptions like that. 90% of the time they make a special version for Toyota manufactured to a different standard. The example is how shitty aftermarket kyb struts are vs the oem kyb struts. Aftermarket kyb struts will give up the will to live after like 60k and the oems will typically do 200k+
    James Finch likes this.
