Is my ABS working correctly?
Discussion in 'Gen 3 Prius Technical Discussion' started by Gasitman, May 30, 2010.
  1. Gasitman
    Gasitman New Member
    118
    Washington
    We have had a lot of rain as of late, and I have found myself sliding when I am braking and my tires hit a manhole cover, or some type of metal on the road. The ABS does not seem to be chattering as I am used to on other vehicles, it seems the tire just slides over the metal. This normal?
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    My experience is that the ABS in the Prius is a little more aggressive (comes on sooner) than other vehicles I've owned/driven and does not "chatter". Part of this is probably due to higher inflation pressure (44/42) that I am using.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    No chatter, buzzing, or thumping with the Prius ABS.
    Tom
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Agree, I think it's probably normal, but you're just sliding over the slicker surfaces.
  5. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I think you're feeling the regen brake dropout.
