Is My Battery Not Charging Fully?
Discussion in 'Gen 3 Prius Main Forum' started by bpollard, Jul 22, 2009.
  1. bpollard
    bpollard Junior Member
    58
    Austin, Texas
    I have attached two pictures - one from the owner's manual and the other from my car. I can't seem to get that last charge bar on the battery.
    Is this normal? If not, is there some other things I can try doing to get that bar? I have already tried braking down a long steep hill (you would think that would be enough to give me the last bar - wouldn't you)?
    Brad
  2. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    That is normal.
    You will rarely ever see it at 8 bars (which isn't actually full, it's really somewhere around 80% capacity).
    As of 3,800 miles, I've only seen it once.
  3. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    It's normal. Check other threads for "SOC", state of charge, for more info.
    :D
  4. bpollard
    58
    Austin, Texas
    ahhh... I just found out what ICE means - now I can add SOC to the list.
    thanks!
  5. DanMode
    DanMode Brooklyn Prius Guy
    98
    Brooklyn, NY
    The only time I ever get full charge is for a few minutes when I'm coasting down a steep hill. Usually when I'm driving down a steep hill or mountain top on the highway. As stated above, it's totally normal.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    What's wrong with you people? When you buy a macbook, would you expect anything less than 100% capacity? Take the thing back!
    [Said in jest of course :D ]
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The control system works very hard to keep the battery SOC at about the two-thirds level. Only unusual conditions will force it to either extreme.
    Tom
  8. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    What John!?
    You said YOU'D hit 8 bars (drinkin') before the car ever will? ;)
    :eyebrows:
  9. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    In my Gen 2, I usually only see 7 bars when I haven't been stopped long enough for the car to do its idle check, once warmed up, so the engine is running excessively at under 30mph. No appreciable hills on my route to work.
    The Gen 3 seems to have a much less stringent idle check routine, if it's there at all.
  10. qbee42
    18,058
    3,073
    Northern Michigan
    The Gen III does have an idle check, but it can do it with less fuss and bother.
    Tom
  11. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    I'm encroaching on 5,000 miles, and I've seen it only a couple of times. The only times I remember have been when driving down the bluffs along the Mississippi. If you are a flatlander, you'll not see 8 bars very often!
  12. felix
    felix New Member
    Savannah Ga
    Why can't I run my Prius III on EV. Each time I get excessive speed override?
  13. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    1500 miles, never seen it. I guessed it was normal, and that seems true. :)
  14. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Ditto, at 3,700 miles
  15. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    Excessive Speed Override means you're going to fast to sustain EV-only. Any speed over 25 (or in some cases, 30) will cause you to get this error. I used to be able to get a car rollin' around 30-32 before it would pop out of EV, but that may have been on a small, small downhill street.
    The rule of thumb is 25+ OR stomping it to get fast response + out of EV she goes!
  16. newtoprius2010
    newtoprius2010 New Member
    Northern California
    I have been wondering about the battery charge myself. I try to do the proper braking technique to get the charge but the battery seems to get down to half or less after every 5-10 mile I drive. I do a lot of small drives so I guess it is in ECO mode a lot, which means it uses the battery. But the battery bar still goes down quicker than what I'd thought it should. I am only 400+ miles on my 3 week old car. Thanks
  17. unkprius
    unkprius Member
    152
    17
    My '11 is only two weeks old, but I've never seen the battery indicator move from it's one bar from the top spot. So far.
  18. newtoprius2010
    Northern California
    Are you driving in power mode? What is your mpg?
    I read an article (I can't find the link at present) where it says the battery is never supposed to be fully charged (apparently that preserves the life of the battery). Also it says that there is no danger of the battery fully discharging (unless someone leaves the light on or something)..apparently the hybrid technology while driving prevents it from ever getting fully discharged (guess the gas kicks in).
  19. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    I used to see it rarely but now see it more often on hills that used to not let it happen. Either battery is more willing or I'm better at regen.
    Anyway, I posted this before: instructions on how to max the bars without a hill.
    All you really need is a few long stops. Accelerate briskly (important, because it forces you to use more of the ICE) and then brake only enough to max out the charge bar. Then repeat this. Stops from 60 or so will do it in just a few stops I've found. Effect is massively compounded if any of these stops are down hill. Why do this? Just because.
    When you hit 8 bars that first time it's a life-changing event. You'll hardly believe your eyes and feel at one with the world, in a good way.
