Is my brake unit going out?
Discussion in 'Gen 2 Prius Technical Discussion' started by tonybluegoat, May 13, 2019.
  1. tonybluegoat
    tonybluegoat Junior Member
    17
    east texas
    I'm certain that I used to hear my brake unit pressurizing up when I got in my 06. Little buzz and hum. I'm not hearing that anymore. Haven't been for a while. Also about half a dozen times (no pattern that I can detect) I get in the car, put my foot on the brake pedal, start it up, then shift into reverse and it starts going backward with my foot on the pedal. Not too far, maybe 3-4 feet. It feels like there's no pressure. Then it straightens itself out. 20 times, no issues, then 1 time it sneaks back on me.
    About 375K miles on the car. Lots of wear and tear. I live on a dirt road so it gets rattled around a lot.
    Just curious. When I back into something I might get a little more than curious.
    Tony
  2. ChapmanF
    15,445
    The system that builds up the brake fluid pressure can wear out, but generally not without multiple trouble codes and (before it gets to symptoms like yours) an ear-piercing continuous high-pitched beep alarm.
    Have you had any warning lights or trouble codes, or asked anybody to cut the wires on an annoying high-pitched beeper?
  3. tonybluegoat
    17
    east texas
    No, I haven't had any high pitch beeping sounds. I don't think I've had any new codes. I would have to look. I have a number of persistent codes that I just ignore. Cat Converter and hot water bottle. thank for replying
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I have had that high beep come on before but unfortunately I have almost no hearing in that range. I only heard it when I moved my head a certain way. I did notice the brake light comes on at the same time. The same light that’s on when the parking brake is set.
  5. Skibob
    2,912
    1,496
    Northern California
    What do you read your codes with? The generic coda readers might not pick it up.
