Is my inverter fried? What to do next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by My2005istoast, Sep 16, 2015.
  1. My2005istoast
    My2005istoast New Member
    Pittsburgh, PA
    I was trying to jump start my 2005 Prius with portable battery, I made the mistake of leaving the "reverse polarity switch" on for a while. When I corrected the polarity and tried jump starting the car again there was dead silence, not a single light on the dash or anywhere came on.
    My question is does the dead dash mean my inverter is fried? What are the cheapest options of fixing a potential inverter issue?
    Andrew Solomon likes this.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Firstly, check for blown fuses. You will most likely have some. After replacing those fuses that were blown due to the bad jump, go ahead and cry. You'll feel better.
    If your car still doesn't start, then know that the cheapest option would be to purchase a used inverter as a brand new inverter costs about as much as the car does at this point.
    Andrew Solomon and My2005istoast like this.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If replacing all the burned fuses (don’t forget the not so easy to find ones) doesn’t fix it. And you do need inverter used one is good since they are not wear item. They really only break either by jump with incorrect polarity or by driving too long with failed inverter pump (warning lights on).
    PS. Is there really reverse polarity switch in jump start pack? Why? That just sound like an accident waiting to happen.
  4. Mendel Leisk
    38,750
    OP, just curious: what's your portable battery pack?
    My2005istoast likes this.
  5. My2005istoast
    Pittsburgh, PA
  6. My2005istoast
    Pittsburgh, PA
    This is the reverse polarity that misled me. I thought I was turning on the battery not knowing I was turning on renerse polarity. In the sun, I couldn't see the red led light come on
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Hmm, there is no "reverse polarity" switch as you stated in the OP rather it's just a warning light you have the cables wrong. Without reading the manual, I would assume this power pack won't allow charging/boosting to occur until the polarity is correct.
    Therefore, I would check the voltage of the 12V battery at rest; better yet, remove and take it to an auto parts store that performs battery testing.
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    yep its a warning light to tell you not to turn the power on you have the wires backwards..
    replace blown fuses,pray,jump correctly,pray some more, order new invert from e bay if needed..pay someone to install it, jumping is the simple part of auto repair it gets a lot harder
  9. My2005istoast
    Pittsburgh, PA
    Thanks everyone. How do I figure which of the fuses are fried?
    Is there a thread where the "hidden fuses are discussed?
  10. Mendel Leisk
    38,750
    You can remove them and examine for a break or discoloration. I think an ohm meter would help too. The fuse box covers typically have a diagram as to which is which, though it's pretty cryptic. 3rd gen has a fuse which is sorta built into the under-hood fuse box base I think, has a thick white cable running to it. Someone got to it (after a similar incident, if I recall correctly) and had to half remove and take apart the fuse box for access.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    First just turn on the headlights. No headlights: check the big white long fuse with clear cover in the black fuse box on the drivers side under the hood. The fuse lead will look blown open. Thats the big one...if that one is blown usually the Inverter is damaged also. Also there's a 100 amp fuse in the battery post assy mounted right on top of the 12 volt battery itself and usually the DOME fuse blows too.
    And yes that reverse polarity is a light on your jump pack if illuminated red is to warn you that the jump leads are backwards so don't turn the pack on
