Is my mpg low? Or about average
Discussion in 'Gen 4 Prius Fuel Economy' started by Recian, Dec 27, 2020.
  1. Recian
    Recian Junior Member
    61
    22
    New Bern, NC
    2018 prius four. I bought it recently and just did my first fill up 470ish miles at 9.9 gallons. My gauge inducted 57 which I know will be a little generous but I didnt expect that much. I'm by no means disappointed with the car just wondering if there's anything I can do to improve. My drive is lots of highway and a little city. I try to set my personal speed cap to 70/71. Car had average 53 when I got it before resetting everything. Tires are the original oem Dunlop aired to 40psi cold and will need to be replaced soon. I'm afraid I'll be low 40s during that break in period unless I change my habits a bit. I did alot of reading on here before buying a hybrid on how to drive them. I go slow forcing it use ev on takeoff until at least 30 mph. I try to let it coast and glide as much as I can. Eco gauge estimate is ~20% ev on that trip. I know some cars have computer memory that learns driver inputs and adapt, does that need time to adapt? Also some gas cars do better mildly accelerating then coast. should i just accelerate a bit more sprited once the engine does come on?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Best not to take much notice of the first fill. Nor the dash gauge. Get a notebook - or Spreadsheet, record every fill and compute the economy. Or use FUELLY - its easy.
    jerrymildred and krmcg like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    1) "My gauge inducted 57" -> reset the "gauge" each fill-up by holding the Trip button until it resets. No telling how long it had been accumulating.
    2) MPGs vary for all sorts of reasons. Sometimes, it's kind of like the "fish story" -- "I caught a fish this big", etc. I wouldn't be too upset with avg mpg of 50-ish.
    3) Yes, new tires will impact it, perhaps a lot. It seems ours dropped about 5 mpg on our new Conti TrueContact from the OEM Bridgestones. Also, we have the 17-inch for a Touring model. 15-inchers should give better mpg than 17-inchers.
  4. Tideland Prius
    16,559
    Well highway driving will eat into the mpg number. A drive on the back roads will bump that 20% EV up closer to 40% and this bring the mpg number up to 60 in the summer.
    IIRC, I was closer to 53-54mpg at 70mph driving so if you’re getting 57, you’re ahead. (We have the 17” alloys so our mpg number will be lower)
    alanclarkeau likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    It looks like you're getting pretty normal gas mileage. Here's our trip to Ohio back in October in my wife's 2017 Prius which was full of stuff. (She packs heavy. :D)
    She actually gets not a lot better in day to day drivings since she makes mostly fairly short trip. I think she gets about 54. If I take it on a 20 mile or so trip in town at 45-50, I'll get over 60 mpg.
    Setting up a spreadsheet will help you track just about anything you want to track. One thing, for example, is how your mileage will vary with the seasons.
  6. Recian
    61
    22
    New Bern, NC
    I figured when I bought it ~50 even not trying too hard shouldn't be too bad and I wasn't wrong. I figured highway is bad for it. When I'm in town it shows 60s and runs ev alot but pretty much ~62+ it can't keep moving without the engine so engine has to run half my daily trip at least. It beats the 32 my nissan kicks was getting and it can actually get onto the highway if I need it. Kicks had no power. I did reset all the trip averages when I got the car.
    jerrymildred likes this.
  7. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    My overall average since August 2017 is 55 mpg.
  8. alanclarkeau
    7,045
    7,592
    Trying to "force" EV mode is sometimes not helpful. Yes, in certain circumstances, like where I know that I've got a long downhill coming up, I might do that - then let it regenerate. But doing it in other situations could mean that you get to a traffic light with only 2 bars of battery - so it kicks the engine on while you're just sitting for 2 mins waiting for a green. Mostly I just let it make its own mind up.
    What I've found with a hybrid (and 2 economical diesels before it) is that it encourages a light right foot, and anticipating traffic and traffic lights.
    dig4dirt, jerrymildred and Harters like this.
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    On my 22 mile commute I drive slower than other traffic and can get 60-65 in the colder months, or 70-75 in the warmer months.
    Drive slower if you want to see some really big numbers.
  10. The Big Sleaze
    289
    64
    'frisco
    2020 Prius
    Two Eco
    I'm at 56mpg lifetime with 33,333 miles total and I never plug in with 2020 Prime base model carrying about 120lbs of assorted junk and I'm about 250lbs.
  11. Tande
    Tande Active Member
    539
    322
    Mich.
    Lifetime avg. 61mpg (indicated)......63000 mi. ......yes, I drive like an "Old/Man" cause I are one! .....
    Christian Bjork likes this.
  12. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    The first few fillups will not be real accurate to your driving since the car has several years of the previous owners history data. Hybrids have a way of adjusting to the drivers style of driving a lot more than gas / ICE cars have. If you want better mpg rule one is go slower and learn howto feather the Go Pedal.
    It's not as important how you get from O to 30 mph as it is how you get from 30 to 60 mph. Although, if you like to go slowly up to 30 mph, the car will eventually adjust to your driving style and try to be as efficient as possible the way you drive the car.
  13. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    I've got an average MPG of 40.3. Doing the math showed me that any vehicle above 33 or 35 MPG has a pretty steep diminishing return on MPG savings. I've more than happy at 40 MPG. I put on better, more capable and comfortable tires on it, and I am not a dangerous road block doing 70 or 71 MPG on the highways.
    Please, guys, the age of being the stupidly slow Prius driver on superhighways needs to end for everyone's sanity and safety. Stop giving us a bad name. You have a Gen4, use the power to go with the flow of traffic. Here, that's often 78 or 82.
    #13 Mambo Dave, Feb 2, 2022
  14. Mendel Leisk
    41,489
    Just curious:
    What’s the posted speed limit in that scenario?
    How does that “go with the flow” work when you’re pretty much alone; you just keep accelerating lol?
  15. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    The only time I recall driving nearly alone was May and June 2020. I did slow down to cruise at 78 to 80 MPH at those times. Posted speed limit is 65 there I believe.
    Now, though, that isn't enough to warrant being in the passing lane (which is the left hand lane for you lane sitters).
  16. Fubar XIII
    Fubar XIII Member
    63
    38
    Metro Detroit
    I think I see why you only get 40 MPG.
    Around here the only people going that fast are the LEOs and those who wish to meet them. Vast majority of drivers are in the 68-74 mph range.
    At our posted 70 mph (remember, it's a speed LIMIT, not a starting point), I pull about 54-56. Above that it drops quickly though I've never been above 75.
    More commonly for me, a trip to Tampa (50-60 mins) or Ft. Myers (close to 90 mins) I'll run 68 on the cruise and pull it up to 58. Sometimes I get all cheap and drop down to 65 and just squat in the right lane unless I have to pass someone (it happens) and push 60 mpg.
    P.S. I seriously hope you aren't driving that Mack at those speeds as you'll give the rest of us Class A drivers a bad/worse reputation.
    Doug McC, Tande and jerrymildred like this.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    833
    Monument, Colorado USA
    Yep, we've seen MPG's from the low-40's to 65 in our two Priis. Depends on a ton of factors, actually.
    Slow Prius drivers? Wow, not in Colorado for sure. We actually have a reputation of driving like bats-out of-hell around here! Folks have even asked me why we drive like that. (I don't) I've seen those drivers, too...where's the fire, pal?????
    Tande likes this.
  18. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    I live in Florida like you. You and I both know that the average speeds are far higher than the speed limits on the highways.
    Commuting to work this morning, all of us - all three lanes - went past a speed trap on a 65 MPH road doing 83 MPH. He didn't pull any of us over. And there you are doing 68?! You are very likely why people forcibly attempt to get around Priuses.
    68 on the turnpike, here, would be putting many people in serious danger as a road block. Please, you save enough at 45 or 50 MPG to not be a @%#@ on the highways.
  19. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Yeah. Everybody drives like Grand Theft Auto. I go 82 in the middle lane and regularly get passed by people going 90+
    ColoradoBoo likes this.
  20. Billy56
    Billy56 Member
    73
    71
    Seattle, WA
    2020 Prius
    L Eco
    Your MPG is a bit on the low side.....substantial improvement is possible. First, I would visit http://www.cleanmpg.com and read about some hypermiling techniques. Over 198,000 miles in my new 2020 Prius, I have averaged more than 80 mpg. It was even higher, until recently I have been forced to do much more freeway driving. There are MANY methods to maximize your efficiency....
