Is my rear wiper blade OEM or aftermarket?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Apr 12, 2023.
  1. SB6
    SB6 Member
    324
    71
    How do I figure out whether my rear wiper is OEM, or if it's aftermarket? I see two numbers on it: 1032-6, and >PET-GF30<
    Haven't really seen any other identifiers.
    I bought a Trico 16-A to replace it, but I'm thinking if it's OEM, I might as well find a replacement insert and return the Trico.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,143
    749
    Monument, Colorado USA
    Most aftermarket wiper blades won't fit our Prius...or they'll seem to fit but actually fall off (or worst, scratch your windows!) (At least that's true for the Gen 4...we have 2.)
    I've found the best solution is to buy just the rubber wiper blades and replace those. Let me look up Toyota Part Numbers for a 2010 Prius II: (Should be less than $20 each and they do last a couple of years, I've found.)
    Rear: 85214-OE050
    Right: 85214-30390
    Left: 85214-68020
  3. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    My opinion, keep the old blade just in case, but I have not found a replacement rubber blade in a long time to fit, in particular the rear.
    ColoradoBoo likes this.
  4. SB6
    SB6 Member
    324
    71
    The problem is I'm not sure my current (old) blade is OEM, so I'm trying to figure out how to tell.
    If it is OEM, I could definitely try to find a replacement rubber insert and keep the OEM. But if the blade is not OEM, I won't be able to find a replacement rubber insert anyway, so might as well use the Trico 16-A
  5. SB6
    SB6 Member
    324
    71
    Anyone? How do I figure out if my rear wiper blade is OEM?
  6. Mendel Leisk
    40,584
    Here's a few snaps of ours, original including the rubber insert, build date Aug of 2009:
    SB6 likes this.
  7. SB6
    SB6 Member
    324
    71
    Are you able to take look at the underside of the blade and see if the numbers 1032-6 or >PET-GF30< appear anywhere?
  8. Mendel Leisk
    40,584
    Will take a look (y)
  9. Mendel Leisk
    40,584
    Yes.
