Is occasional sloshing sound normal when heat is on?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HogMedia, Oct 20, 2022.
Tags:
  1. HogMedia
    HogMedia Junior Member
    2020 Prius Prime
    I noticed when I turned the heat on my 2013 Prius so I could sleep in it that there is this occasional sloshing liquidy sound coming from seemingly around the dash. Is this something I should be worried about?
  2. ChapmanF
    15,618
    There could be some air in the cooling system. What level do you see in the engine coolant reservoir? Has the coolant ever been changed?
