Is oil change part of 5k "free" service?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cyclopathic, Mar 25, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Or they just doing tire rotation? thnx
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Oil/filter is not part of 5K.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    even if it falls under "heavy use" schedule?
  4. fuzzy1
    10,035
    The 'free' service includes only two oil changes, and three other visits for tire rotation. When I asked, visits could not be taken out of sequence, but I was allowed to take the oil changes early by foregoing the prior tire-only visits. So, because I generally get the first couple new car oil changes early, I had two oil changes, plus one separate tire rotation, then was going to my preferred independent shop for oil changes at my own expense before 25k miles. The other two tire-only visits were flushed away.
    #4 fuzzy1, Mar 25, 2015
  5. cyclopathic
    3,292
    547
    2014 Prius c
    Thanks!
    On new car I try to replace oil filter after fist 1,000mi. I didn't on this one b/c it was cold, it snowed and filter was screwed on so friggin' tight.. may try to do it now and don't wait? If I can't get it off would have to take oil change.
    I do my own changes but free is free it will save me 60-70 bucks.
  6. frodoz737
    4,297
    2,347
    33
    ;) Smart move to change out first oil/filter early. I still do both every 5,000 miles...but that's another discussion/arguement.
  7. cyclopathic
    3,292
    547
    2014 Prius c
    Agree completely. I've seen huge pieces of metal shavings from manufacturing after 2nd oil change in the past.
    My basic problem with taking it to the shops oil may be completely cold and all deposits settled/stuck to the walls by the time they get to it. That and use of sub-par oil/filter.
  8. Okinawa
    Okinawa Senior Member
    1,333
    317
    They just do a tire rotation at 5,000. At 10,000 they do oil and filter change plus tire rotation.
  9. frodoz737
    4,297
    2,347
    33
    There are various solutions/solvents made for "flushing", though used more for high mileage and neglected.
  10. bisco
    48,930
    i had them do my first free oil change at 5,000, then the second at 15,000. it makes no never mind to them, you get two free, and that's it.
  11. Janstheman
    Janstheman Junior Member
    48
    Worthsville, IN
    It seems that Toyota is trying to get a handle on oil gelling issues with their engines. At the two "free" oil changes, Toyota uses synthetic oil to stop this from happening.
    It is better to pay for oil changes than ANY engine work. This builds rapport with the customers that the dealership service department is not going to rip them for money. And if you start with synthetic oil you are more likely to get this oil again.
    Our family has had seven Toyota products in the past ten years. We have used Mobil 1 at the dealer with zero problems in any of these vehicles.
    My advise is to use synthetic oil for long term durability and less maintenance cost (no out of warranty repairs).
  12. cyclopathic
    3,292
    547
    2014 Prius c
    Asked at the service counter and they said no; if you want it you have to pay for it. So it varies from dealer to dealer
  13. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    I had quite a discussion with my service adviser.......TWO of them in fact.......trying to get them to understand that the first 2 oil changes were complimentary and it really makes NO difference what mileage I decide to "cash in my coupons", as it were.
    I did my first at 5K and am approaching the second one at 15K. I did not do a visit in between. I strongly suspect this will confuse the crap out of them.
  14. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    The cost for an oil change varies quite a bit. My dealer will perform an oil and filter change for $19.95 and the oil is synthetic. They also do a safety check and rotate the tires while changing the oil!!! I'm sure they do it to get the customer to come back for service. It works for me, what they charge is less then I can change the oil for and they really provide excellent service. Additionally, I really like my C2. Life is good.
  15. Okinawa
    1,333
    317
    Good deal. I would take that for as long as I could get it.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    At 5000 miles I paid for the oil and filter change. Then let Toyota Care pay since then.
    Not going to debate the value of doing it or NOT doing it. I've never owned a new car where I waited as long as 10,000 miles for the first oil change, and I just couldn't do it with The Prius.
  17. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    A few people have reported success arguing for it at their dealer. Been doing 10k OCI since 2003 when Honda recommended it on a Civic. The 5k mile dealer visit wasn't a total waste for me, I had them turn off the reverse beep. 2 years later, I'm still pissed the service advisor said he can't turn off the reverse beep. Then while I'm gathering the strength to argue, he says he can do one beep. Jerk.
  18. bisco
    48,930
    i got the 'we can't do it at 5,000' too. told him thanks, i'll go to another dealer. got the 'wait, let me talk to my service adviser'. :rolleyes: then came back with the 'okay, we can do it'. not too happy about it though. must be like working at the dmv, a lot of grumpy people.
  19. cyclopathic
    3,292
    547
    2014 Prius c
    I was planning just to replace filter after 1,000mi.. bought filter but could not get the filter off the car. Whomever put it on in factory must have really strong gorilla grip as my oil filter wrench (socket type btw) end up rounding filter off. I suppose I could have punched screw driver through the filter and got it off, but.. let them deal with it at 10K.
    The main reason I brought Prissy to dealer to get alignment checked. And they did a good job with it, so I won't complain.
    BTW both front wheels were toed-in more then 1/2" from the factory.
  20. bisco
    48,930
    is that a bad thing?
