is piston soak a good idea at 150mi on 2006 slight blow-by
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chris77*, Mar 19, 2024.
  1. Chris77*
    Chris77* Junior Member
    57
    16
    I am curious what does priuschat actually think about doing a piston soak on a 2006 with 150,000 miles? I picked up this old prius last year and it is due for the first oil change. I put 4k miles on it in a year and it burned 1/2 quart. I cleaned MAF, throttle body, pcv valve and line, this was a noticeable improvement. The piston soak seemed like a good idea and not that hard to due but I don't know if there is some risk involved? The instructions I have are to use a turkey baster to pull out the fluid after the soak. This because have to get it out or will hydrolock the engine. I have a miserable place to change oil so I was told that I could drive it a few miles to get a oil change as long as I let the car warm up after removing fluid. I can even rent the borescope for free to take a look down in there. What do you guys think is the risk worth the reward or should I just do oil change and let her go? TY
  2. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    I have never done a piston soak, but for as little as you drive it, it’s probably easier to just add an eighth quart of oil every 4 months/ top off as needed!
  3. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    Agreed, at 4k a year you mostly need to worry about keeping mice out and 12v charged. Just keep topping up with the cheap stuff, not worth the hassle of a soak.
  4. Chris77*
    57
    16
    I didn't have to add any oil. I am just trying to get the car in as good of shape as possible. Because it's a good car and I want to treat it nice so it will last me.
  5. Chris77*
    57
    16
    I have been working from home we take it out once or twice a week and took one road trip last year about 1000mi. The road trip is when most of the blow-by happened. Otherwise no problem with the batteries holding charge, it still has original hybrid battery and it runs like new. Gets 45mpg easy.
  6. nancytheprius
    356
    152
    iowa
    Excellent! Keep driving it as often as possible and the car will be happy! My 2006 has 118k miles and is very reliable. Have a backup plan for your OG battery but don’t let it consume your thoughts haha
    iPhone ?
  7. Chris77*
    57
    16
    I have back plan for the hybrid battery. I am either going to by a new one for $2250 or maybe get gen 4 cells on a salvage at around 100,000mi. I understand the gen 4 cells are compatible with my current battery pack. This could be done for 1000$ if I can find the junker. Which do you think is better?
  8. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    Awesome! I wouldn't expect that hybrid battery to be long for this earth, but milk it for all you can!
    I love hearing about one lasting that long, makes my day.
  9. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Piston soaks are a last resort before giving up on engine... While they will limit oil loss, the solvents can do lots of damage to gaskets and seals. Losing a 1/2 quart of oil per 4K miles is normal for an old Prius. Once you lose more than a quart per thousand miles you might want to consider it. But if you're only driving 4K a year you'll have plenty of other problems before you have to worry about this one.
  10. Chris77*
    57
    16
    Thanks for the clarification.
  11. nancytheprius
    356
    152
    iowa
    If you’ve got the time and energy then saving the 1-2 grand to get a fun/rewarding project would be better in my opinion. Plus your driving habits probably justify that solution more. I went with the new one but I drive mine three times as much as you and wasn’t near many other Priuses for hand-me-downs. You’re making me want to buy a second Prius and work on it haha
  12. Chris77*
    57
    16
    From what I have seen swapping cells is easy. Hard to get the pack out with one person and with slight risk of electrocution. Maybe I will hire a mobile mechanic to help me out for an hour or two. I don't think it will be too hard to find gen 4 cells but not really for sure yet. If can't find salvage cells, I guess I buy a new pack and then sell it if/when car dies.
  13. nancytheprius
    356
    152
    iowa
    Yeah I did everything myself except had a friend help me carry the battery in and out. If you’re attentive to details and take before after pictures you’ll be capable. The orange safety interlock will be your lifesaver
  14. Chris77*
    57
    16
    Thanks for your advice today. I love priuschat. I always get top notch advice here.
    PriusCamper and nancytheprius like this.
  15. dolj
    dolj Senior Member
    7,661
    3,879
    Wellington, New Zealand
    Instead of a piston soak, when you do your next oil change I'd recommend adding 300 mL (10 (US) fl oz) engine flush (Wynns, Penzzoil, BG amoung others) to the engine oil and then run the engine for 20 mins (or as directed by the product instructions) before dumping the oil. I do this as standard now. I started off doing this as a short-term process, but I have found it gets so much carbon and soot that I am just doing every oil change. If ever the oil is not jet black, I'll consider doing it less often.
    YMMV.
    PriusCamper likes this.
  16. Mendel Leisk
    38,735
    That's not bad, I would just keep an eye on it, have an extra quart on hand for top ups.
    It's funny, I've noticed a lot of Amercans stumbled over quart "fractions". I'm old enough to have learned and grown up with "imperial" meausrements. An "eighth quart" for example, could also be called "half a cup".
    Similarly, OP's "1/2 quart" becomes "a couple of cups". Or maybe more succinctly: "a pint".
  17. PriusCamper
    11,106
    4,520
    This stuff works pretty good if you have an engine that wasn't getting it's oil changed often enough and is extra dirty. Though a full size bottle is designed for larger engines and so I do half a bottle on first oil change and the other half on its next oil change. And I Only run engine for 5 minutes, not 20 minutes before the oil change, as long as engine is at operating temperature before you pour it in.
    dolj likes this.
  18. Chris77*
    57
    16
    Engine oil is not black more of just darker brown than normal.
  19. dolj
    dolj Senior Member
    7,661
    3,879
    It will be black when you use the engine flush.
  20. Chris77*
    57
    16
    Isn't there some risk of destroying catalytic converter doing this? I assume this is why you recommend half strength and for 5 minutes only? I think it might not hurt the maf, throttle body and pcv was super filthy when I cleaned them. TY
