Is stale gas a problem?
Discussion in 'Prime Plug-in Charging' started by Dan Martin, Aug 12, 2019.
  1. Dan Martin
    Dan Martin New Member
    2019 Prius Prime
    Technology
    I just recently got a 2020 Prime and drive mostly on electric. I estimate a tank of gas can last 3500 to 4000 km based on my typical usage. Should I be looking to add a fuel stabilizer to the tank?
    I'm assuming keeping it topped up is best so I don't get water condensation in the tank. Should I also be using premium gas if it's going to sit for a long time?
    Thanks
  2. Tideland Prius
    16,126
    Officially? The manual says add at least 20L of fuel every 12 consecutive months. Also, a service technician at my local dealer also said it should be fine to leave it for more than 6 months.
    So if you take Toyota at their word, you’ll be fine.
    But if you want to take preventive measures (cause it doesn’t hurt to be extra careful), then yes look for ethanol-free fuel (I find it’s cheaper to refuel on 91 ethanol free in the US than pay Canadian prices). You could add fuel stabilizer too. But if you go through that 3,500-4,000km in 4 months, you should be fine.
    Also, the gas tank is pressurized to reduce gasoline vapours. By that logic, water condensation should be minimal in the tank.
    My first dealer tank lasted almost 6 months and 7,000km. And I only refuelled 60% of the tank (still had just under half a tank left). I had to because I was on a road trip.
    jerrymildred likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    How LONG do you figure it will be before you need gas.......that is, down to half a tank ?
    In this discussion, time is more important than mileage.
    No advantage to premium gas unless it is also ethanol free. Then an assumed slight advantage.
    I would lean toward the 6 months theory.
  4. Dan Martin
    2019 Prius Prime
    Technology
    Thanks everyone, this is helpful. I’ll probably need to fill up every 3 or 4 months, so it doesn’t sound like I need to do anything special.
  5. bisco
    49,377
    i only buy a couple gallons at a time. i never considered condensation, is that a problem in modern fuel systems?
    Arctic_White likes this.
  6. sam spade 2
    7,035
    2,788
    2017 Prius c
    In general, no.
    If you live where the spring and fall sees WIDE swings in the temperature over a short period of time......then maybe.
    There is NO good reason to top up the tank with only a couple of gallons at a time under normal circumstances.
  7. MSantos
    MSantos EcoAccelerometry
    577
    250
    Canada, Winnipeg
    2018 Prius Prime
    Technology
    Several years ago I had a good conversation with a long-time friend of mine who was working as a chemical engineer in Edmonton regarding this topic. Here are the highlights I recall:
    - Gasoline/Petrol oxidization is one of the biggest issues. As long the vehicle has no evap related codes then there are no detectable leaks in the system. Oxidization worsens when leaks are present even when they are too small to be detected and still within the design tolerances of your vehicle's evap system! So the advice is to add stabilizer to the fuel in the tank at least once a year if and only if, you do not add a good amount of fresh fuel at all. Toyota's recommendation (see user's manual or previous posts) is very sound on this account.
    - Condensation and moisture, in general, is another big issue too. Temp cycling can promote condensation which is not ideal. This may also be worsened by the presence of ethanol in the fuel and the various percentages one is likely to find in North America. Let's say the concern is highest with the higher percentages of ethanol. ;)
    - It appears Gas/Petrol may experience some stratification when left still in a sealed container for extended periods of time. I suspect the constant physical agitation of the fuel on board of a PHEV driven primarily in EV mode is a strong mitigator for this concern. This is why I take the claims of "fuel aging" with some skepticism unless they include meaningful specifics.
    Anyhow... in my particular case, I still have the dealer gas in the tank 1.5 years after delivery, a little over 10k miles and tank currently 1/3 full.
    I added one bottle of stabilizer just before the 2018 winter arrived. Will do so again in October or November this year unless I add fresh fuel before then.
    Cheers
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I agree with your friend. Gas sitting in a plastic jug with a vent will have problems eventually. But a modern car's tank is well sealed and the Prius tank is pressurized, too.
    As for the length of time you've been on the original tank? Just WOW!!! I got mine in early March this year. If not for a big 6,000+ mile road trip in May, I'd still be on the second tank. I take too many trips beyond battery range to stretch a tank that far. Current tank is almost to 2,500 miles. But I may decide to fill it tomorrow. I'm at 1/8 and need to make a fairly long drive Thursday to pick up friends at the airport.
    MSantos likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,250
    I have two cars that only get fresh gas every two years when they are due for pollution inspection and have never had any problem with them starting.
    They do get started occasionally and sometimes I remember to put fuel stabilizer in them. I have too many cars and can't drive them enough and don't recommend treating a car this way.
    Water in your gas from condensation ended with modern fuel systems and most tanks are plastic today so only the air that is in the tank can have moisture to cause a problem. Don't over think it, put some gas in it and run it occasionally and you will be fine.
    MSantos likes this.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I used to run Ethanol fuel stabilizer, but NOT anymore.....
    I switched over to real gasoline (E0) many months ago, I run it this way for all of my local driving because this gas just sits in the tank and barley gets used.
    When I'm planning a trip I switch back over to cheap 10% Ethanol gasoline (E10), then with a little strategy I come back home from my long trip with virtually an empty tank. This way when I arrive home I can fill up with a fresh ~1/2 tank of Ethanol free gasoline and re-start my months and months of local driving knowing there's no Ethanol in my tank.
    Rob43
    Prius from Dad and MSantos like this.
  11. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    Less gas in the tank = less weight, so faster acceleration and better efficiency. Although I haven't noticed any difference.
    MSantos likes this.
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    What exactly do you think is good about letting it STAY that low on gas ?
    I think nothing.
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    Imagine that !!
    :ROFLMAO:
  14. fuzzy1
    10,150
    If he is that successful at using the car almost entirely as a BEV, then why exactly would it matter what level he keeps his gas tank?
    I can think of no good reason why it is either good or bad. Well, besides the fact that in the event of a collision-induced fire, a lower fuel tank will produce a smaller inferno.
    #14 fuzzy1, Aug 13, 2019
    jerrymildred and Prius from Dad like this.
  15. NSXT
    NSXT Active Member
    137
    118
    Toronto, Canada
    2018 Prius Prime
    The low fuel light will be on for a long time and the fuel sensor will be over used :ROFLMAO:
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    That's really impressive.
    And that's what I don't think Toyota communicates enough IS possible with a Prius Prime. Of course usage habits vary. But the fact that you can reach that type of SUPER fuel economy is something that I don't think the general public understands.
  17. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    It's not really a matter of fuel economy, since the indicated or calculated mpg only accounts for gasoline usage and not for the energy provided from the wall socket. It is a very efficient vehicle but you have to include all energy costs (and usage) in the assessment.
    jerrymildred and The Electric Me like this.
  18. sam spade 2
    7,035
    2,788
    2017 Prius c
    A lot of speculation is involved.......ie guessing.
    A large "air" pocket in the tank is more likely to exchange more air with the atmosphere, possibly resulting in more water in the gas.
    Then....stuff happens.
    What if there is a MASSIVE storm that cuts the power for weeks.
    Living in Florida, this is a real concern and I'd prefer to have a full tank when/if something like that happens.
    Things can happen on a smaller scale that might limit your access to fuel too.
    Then there are things like a personal tragedy occurring and you taking off on an unexpected road trip when you aren't thinking exactly straight and running out of gas on the way.
    I guess it is a personal choice......but I see no practical reason for leaving it low like that.
    And several possible reasons for NOT doing that.
  19. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I leave the tank low when I'm around town so I don't haul a tank of fuel around for a few months. At start of a road trip I fill up and hit the road.
    If a massive storm is headed our way (these are generally predicted well in advance) the option is there to fill the tank.
    I don't expect it would be easy to run out of gas on a sudden road trip. The car starts warning you about fuel at least 75 miles from empty and even offers to find a gas station.
  20. Bill Norton
    Bill Norton Senior Member
    1,834
    601
    MONW, Ks.
    That is a great point.
    An empty tank 'breathes', just like caves.
    Much more air is exchanged at each and every barometric change, bringing in a new batch of humidity with each high swing.
    And alcohol absorbs that humidity.
    Could be bad, unless you live in Las Vegas where they always say, "But it's a dry heat!".:whistle:
    It's better to tote around a tank of gas. It's more weight but you'll never be able to measure the fuel economy differences.
