Is stop and go freeway driving the optimal mpg?
Discussion in 'Gen 2 Prius Fuel Economy' started by burritos, Jun 25, 2006.
  1. burritos
    burritos Senior Member
    4,946
    252
    Seems like whenever I'm in congested freeway driving where there's some stop and go, my average mpg seems to pick up.
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Same here. I obtain my best mileage while driving on the freeways when traffic is heavy and it takes me half an hour to forty minutes to travel a distance of ten to twelve miles (most often on the 101 southbound/Ventura eastbound).
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    My guess is that you are benefiting from a warmed up engine and slow speed.
  4. burritos
    4,946
    252
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jun 25 2006, 06:57 PM) [snapback]276665[/snapback]</div>
    Same here. Yesterday, while on the 101 between Woodland Hills and Hollywood, I got somewhere around 70-80mpg. After I got on the 134 and sped up to a steady 60-70 mph, my effeciency decreased to 40-50 mpg.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Because those traffic patterns almost force you to pulse-n-glide,
    which is well known to be the optimal use of the HSD for fuel
    economy. If you extend the methodology into as much of your normal
    driving as possible, per the numerous articles that have been posted
    here and elsewhere, you'll realize those benefits more often and
    your overall average will go up.
    _H*
  6. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    It depends on what average speed the stop and go traffic is moving along at.
    I find that I get better mpgs when there is enough congestion on the freeway to slow traffic to 20-40mph with few sudden stops/slowdowns (I try to stay in electric mode and coast as often as possible in the slow lane when traffic is like this).
    Stop and go traffic in which you actually stop & sit for a period of time (5-20 seconds) in between the go's and never quite get much speed up before you have to brake and sit again eats away at my mpgs and the battery level. I opt to take surface streets when I encounted truly stopped up traffic.
    This is what my optimal freeway traffic journey looks like on the mfd:
    I like that!!
  7. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    I find this true for "slow-and-go" where there are few complete stops but heavy traffic. In the summer, with A/C on, this doesn't work as well.
    Very heavy stop and go traffic only gives good MPG for a short time. Eventually, the battery depletes and the engine comes on every time I move and shuts off immediately. This isnt' very efficient.
  8. comatoes
    comatoes #GreenLife
    288
    17
    I find my battery being depleted often when I'm cralling to stop lights, what is the best way to get mpgs in this situation? When everyone is inching up and I just always see the battery draining.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The battery will drain in those situations, which is exactly what it should do. The alternative is to run the engine, which is what a conventional car does in the same situation. That isn't very efficient.
    In stop and go, your Prius runs from the battery until the battery is low or the engine needs heat. At that point the engine runs until the battery has some charge and the engine is hot. Repeat as necessary.
    Stop and go is not efficient, even for your Prius, but your Prius is less inefficient than a conventional car.
    What's the best way to get MPGs in stop and go? Find another route. If you have to drive that route, just drive and your Prius will take care of it.
    Tom
  10. hill
    8,640
    Or if you can change your work times - that can help. I start my driving day well over an hour before the sun comes up. The I-5 and I-405 junction (near where I live) is over 20 lanes across (north and south bound). Two hours after I pass through, it's often grid locked. When I pass through I'm lucky to even see 2 or 3 cars - all the way to the horizon. Timing can be everything.
    oh! almost forgot
    ZOMBIE THREAD - it was dead for over a half decade ... & now it's alive!
    :p
