Is synthetic oil required? (Too lazy to check manual!)
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by prevee5, Oct 19, 2013.
  1. prevee5
    prevee5 Member
    114
    Monrovia, California
    Is synthetic motor oil required in the Prius v? If so, what weight?
    Local independent mechanic quoted $75 for oil/filter change. Said he'd do it for under $20 if I supplied the oil.
    So looking for good deals on oil as well.
    Right now I'm covered with 2 years of oil changes under Toyota Care. But just getting prepared.
    Thanks in advance!
    2012 Prius v mod. 5
    49,512
    i think so, but you're better off with it anyway, worth the extra $$$. there are threads her, i think walmarts has it on sale now and again.
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Your Prius requires 0w20 weight motor oil which is synthetic. Synthetic is a little
    higher than regular motor oil but only needs changing every 10,000 miles. So far the
    best price per quart I found is NAPA auto stores, they had their brand, 0w20 synthetic oil for $3.49 / quart, which
    is made by Valvoline....
  4. Mendel Leisk
    38,742
    You need 20W50 weight, year 'round. Trust me.
  5. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  6. prevee5
    prevee5 Member
    114
    Just saw in the latest Costco coupon book:
    Mobil 1 10W-20 or 10W-30......6qt / $27.99 after $10 instant rebate.
    Good price?
    Should I stock up?
    What is shelf life of synthetic motor oil?
  7. BuckyB
    BuckyB Junior Member
    48
    Chatsworth, Ca
    2013 Prius v wagon
    10W-20 and 10W-30 are NOT what Toyota recommends in the manual. Like alfon and JimboPalmer said, 0W-20 synthetic is the right answer. So to answer your question above, No. Do not stock up on the wrong oil. There is no such thing as a good deal on the wrong stuff.
  8. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Walmart prices on 5 qrts 0W-20 Mobil1 consistently run less than $27 per 5 qt jug...a couple of jugs will probably last you well over a year. I've not changed the oil and filter on my 2013 since dealership will cover it for 25,000 miles but I'm prepared to do it myself and spend a total of no more than$35 per change...although I wish they had kept the standard filter instead of a cartridge since they tend to be messier.
    Welcome !
  9. Mendel Leisk
    38,742
    I follow a just-in-time approach: getting oil, filter cartridge and drain plug washer all together from the dealership parts department, often on the day I do the change. I buy liters (qts in the States) of Toyota's oil, typically under $6 per.
    (check the oil filler cap: it says 0W20)
  10. prevee5
    prevee5 Member
    114
    Hey, thanks for all the great info!
    I saw the 0W-20 right there on the oil cap.
    According to the Mobil1 website, their shelf life is stated as 5 years. But no need to stock up yet as my Toyotacare "free" oil changes are good for another year. I did read on another forum that Costco does not carry this weight of oil....but said products vary by location. Great tip on the Walmart deal though snead_c...will definitely have to keep them in mind.
  11. mikefocke
    3,702
    1,649
    Sanford, NC
    Don't assume the oil is changed just because the light is shut off. Look at the invoice even though it is free. Happened to me the other day at the dealer and I said I want it even if I have to pay for it. Then somehow they covered it.
    snead_c likes this.
  12. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    My local Toyota dealer charges less than $75 for that same service.
  13. orenji
    orenji Senior Member
    5,884
    3,486
    The light comes on at 5K mile, Toyota only changes the oil at the 10K mile marks, so if you want to change your oil every 5K miles you will need to pay for every other oil change. BTW Toyota oil is Mobil 1 oil. Dealer charges $75.00 for the oil change service.
  14. Mendel Leisk
    38,742
    Not disputing that (I use the Toyota oil), but just curious: any sources for that?
  15. orenji
    5,884
    3,486
    Toyota Dealers and techs will inform you that Toyota oil is made by Mobil. There is also plenty of information on this on the web.
