is the body of a prius made out of aluminum?
Discussion in 'Gen 3 Prius Main Forum' started by tevogel, Feb 2, 2012.
  1. tevogel
    tevogel Junior Member
    40
    slater,mo.
    2015 Prius Alpha
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It has aluminum hood.
  3. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I think the hood and tailgate are, but the rest is steel.
  4. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    You're right and plastic bumpers.
  5. bisco
    49,488
    when i had to replace the tailgate on my 04, it cost me a bundle.
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Ahh yes, all replacement parts are made of gold. :eek:
  7. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    Someone rear ended me and the rear bumper was replaced. The shop said it was made in Taiwan.
  8. Silver bullit
    608
    210
    Curious. Why the mix of aluminum and plastic? Why not all plastic or all aluminum? Weight? Strength?
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Sure it was not Thailand or maybe they were confused?
  10. Silver bullit
    608
    210
    That's possible. Maybe I heard it wrong. Are they made in Thailand?
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Bumpers are ideally deformable, but re-formable. They should bounce back.
    Body panels are judged by tight seams, a deformable part will not have tight seams, Saturn used plastic body panels but was blasted for poor fit and finish.
    Design News - Blog - Finally We Get Some Truth on Plastic Body Panels
    http://www.i-car.com/pdf/advantage/online/2007/100107.pdf
  12. Guy in WNY
    Guy in WNY Junior Member
    83
    17
    Western New York
    2018 Prius Prime
    the front bumper is also aluminium under all the foam and plastic. They replaced mine after the dog/car incident as it was bent.
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Yes sir Priuses are made currently only made in Japan and Thailand.
  14. Eoin
    Eoin Active Member
    593
    116
    Long Island
  15. Tideland Prius
    16,154
    Hood, hatch, brake calipers and I think a few suspension bits are aluminium. The rest are steel (except the bumpers which are plastic) AFAIK.
    All aluminium is too expensive (see NSX, XJ and 1G Insight).
    All plastic = panel gap issues, aerodynamics, wind noise (plastics expand/contract much more than steel. See Saturn or smart fortwo and look at the size of the gaps between exterior panels).
  16. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  17. bisco
    49,488
    i only had a small dent, but according to the body shop, you can't repair aluminum.
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    wait... i thought it was the doors, hood, roof, and rear hatch. the actual body panels that connect to the rocker panel are not aluminum. and of course as everyone said, the bumpers are plastic.
    i didn't think about the suspension parts...
    as for repairing aluminum... i thought you can but it requires heat and a lot of pressure?.?.?... (not 100% fixed but enough after it's repainted. mainly smaller dents)
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You can, but aluminum work hardens. Pounding out a dent will create stress lines that will ultimately crack.
    Tom
  20. Tideland Prius
    16,154
    I think they changed the doors to steel for 2010. They sound different from the aluminium doors of the Gen 5 Camry.
