Is the final "grunt" on stopping normal?
Discussion in 'Gen 5 Prius Main Forum' started by tovli, Nov 11, 2024.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I have been coming to a stop in my 2023 Prius Prime XSE for 16 months the same as I did with my 2008 Prius: anticipate the stop by applying light braking, then a little more braking till rolling quite slowly (till regen braking is no longer the main force), then ease off the brake progressively while slowing further until the vehicle stops.
    In my 2023 Prius Prime XSE, all stops end with a quiet "grunt", that I did not often hear with my 2008 Prius.
    Is this final "grunt" normal in the 2023 Prius Prime?
  2. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    My 2019 Prime does the same under the same scenario as you describe. That's normal. It is the cold brake pads on the rotors as the vehicle comes of regen braking and applies the cold brakes onto cold rotors. The kinetic energy is dissipated as sound instead of heat.
    tovli and Trollbait like this.
  3. Gokhan
    Gokhan Senior Member
    6,217
    2,465
    Paramount CA
    It is not. My 2021 Prius Prime Limited brakes are always whisper-quiet, and I didn’t hear brake noises when I test-drove a Gen 5 Prius XLE/XLE AWD. Gen 5’s stops are a lot smoother because of better brake modulation in the Toyota Hybrid System III (THS-III).
    tovli likes this.
  4. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    does your Prius make "grunt" noises when you let the break go lightly so that the car starts crawling forward against the brakes and the lightly apply brakes again. My 2019 does and that is normal. Speaks of polished brake pads due to mostly regen braking and light braking. A few hard brakes from speed takes the polishing off the brake pads. Nothing that give me reason for concern.
    tovli likes this.
  5. Gokhan
    6,217
    2,465
    Paramount CA
    If you can hear any brake noise over the Prius pedestrian-warning sound, it is not good.
    And don’t try to fix your brakes by braking hard—it only makes it worse.
    tovli likes this.
  6. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    No pedestrian-warning sound on our New Zealand models so we hear any little squeak on stopping in EV mode, even the regen braking cogging of the electric motors before the mechanical brakes take over on a slow stop.:)
    tovli likes this.
  7. GcinFl
    GcinFl Junior Member
    42
    2024 Prius
    Mine was doing something similar one day until I realized I had accidentally pressed the "hold" button on the console. It would hold a little on going forward from a stop. It may have made a sound when it stopped too. Might be worth a look.
