Is the Gen 3 prius unreliable?
Discussion in 'Gen 3 Prius Main Forum' started by Mark10V, Dec 24, 2020.
  1. Mark10V
    Mark10V New Member
    nl
    I was seriously considering buying a Gen 3 Prius or a v/+ until i started reading this forum.
    Is the image of the Gen 3 having headgaskets, oil burning issues, ABS actuators, Inverters etc correct?
    And if so, how did the Prius get the image of the reliable car with low maintenance costs?
    I see lots of taxi company's driving them but reading this forum it would seem there are lots of problems.
    I'm reading lot's of people on here saying skip the Prius and get something else, which really surprises me.
    #1 Mark10V, Dec 24, 2020
  2. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
  3. Mark10V
    Mark10V New Member
    nl
    thanks for the reply, however that only tells me that there are 191 topics that have a combination of gen 3 and problems in the title.
    It does not really tell me anything about how reliable the car is.
    Threej likes this.
  4. bettergolf
    bettergolf Active Member
    417
    334
    Sanford NC
    It's very reliable. Not many people come here to post how great their car is, they come here to find solutions to a problem, hence the negativity. The biggest negative in my opinion is when something does go wrong it's often expensive to get repaired. Mine has 64k on it and has had no problems at all. I replaced the 12v battery and the tires and have kept the oil changed, that's all. But honestly I wouldn't buy a G3 with over 100k miles unless it's almost free.
    #4 bettergolf, Dec 24, 2020
    Salamander_King likes this.
  5. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Any car that has neglected maintenance, or high miles, or driven abusively, or involved in a wreck will most likely become or is unreliable. Do your homework of the vehicle's history, hope the previous owners drove the vehicle like a grand parent w/low miles on the clock.
  6. Rmay635703
    Rmay635703 Senior Member
    2,591
    1,608
    Somewhere in Wisconsin
    2013 Chevy Volt
    If your looking at a 2010 get a 2009 instead
    If your looking at a 2015 get a 2016 instead
    if your looking at a 2013, then understand the extra egr, catchcan and shorter OCIs are likely prudent and sometime around 150,000 miles you can potentially expect a bad head gasket and having cash to repair/replace after that point is needed.
    Nobody on the board recommends an old Prius (which Gen III IS IN) unless you are a hobbiest that will diy or have the money in the bank for a repair
  7. Mark10V
    Mark10V New Member
    nl
    I'm quite used to buying used cars and have a keen eye for spotting loved examples, thing is i'm seeing people in the forums
    litteraly saying they would never buy one again and saying not to buy one, like in the oil consumption thread.
    The ones i'm looking at are in the 2010-2014 range and with 100k-150k
    I'm looking at different types of Prius or a CT200 or even an Auris TS.
    Right now i'm driving a Volvo S80 2.4 with 200k miles 2001 year which was pretty carefree for the 5 years i've owned it so far.
    I'm drawn towards the Prius because of the MPG and bulletproof reputation, but got a bit spooked because of some of the reaction on this forum.
  8. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    Buying used is always a gamble. My previous two Prius were purchased used, lease returns, the last one was a Toyota Certified Used Vehicle which provided some additional warranty and peace of mind that all systems were go. My 2011 Gen III was very reliable during the six years and almost 200K miles I drove it. If you have a vehicle in mind already I would recommend going to the Toyota Owners website and creating a profile. If you have the VIN of the vehicle you can plug it in there and see the maintenance record and any other concerns addressed by a Toyota service department. Good luck.
    MexicanChip likes this.
  9. Mark10V
    Mark10V New Member
    nl
    A 7 year old Prius is considerd a bad buy?
    Yikes... My current car is 19 years old and has been very reliable...
    This is exactly why i started this thread...
    If a Gen 3 is considerd old, i mean the youngest Gen 3 is like 5 years old.. That can't be considerd old right?
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    I think frequent oil changes while the engine is low mile and clean will keep it that way longer, even with known piston ring issues. Reduced oil consumption will keep the oil out of the exhaust, which in turn will reduce the gunk in the cylinders.
    It seems clear that small coolant leaks into the cylinder can go on for months with little impact but its certainly a game of engine hydrolock russian roulette that often bend connecting rods and sometimes blows holes through the block.
    Then there is the fact that Toyota rerouted the egr intake to downstream of the catalytic converter by the fourth generation. Let the cat clean up unburned oil and fuel before dumping it back into the cylinders via the egr. Of course the rings and pistons were upgraded late in the gen3 run. Reduce oil burning and fuel blow-by. Makes sense. Almost like science at work.
    #10 rjparker, Dec 24, 2020
    AzWxGuy likes this.
  11. Mendel Leisk
    38,644
    I’d think it’s virtually all air-borne mist, and only a portion condenses/remains in the intake; plenty of the mist (an oil/water olio) is steadily passing through, to the combustion chambers.
  12. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    apples vs orange, but feel free to believe two different technology will have the same longevity and functions reliability
  13. Johnny Cakes
    Johnny Cakes Senior Member
    1,010
    761
    Virginia, USA
    Please try to be nice to the new people. The rest of us are used to you.
    And the OP was only saying that older cars aren't necessarily unreliable. Different technologies notwithstanding.
    Before pulling the trigger on a purchase, he's just trying to get footing on the disconnect from his the Prius reputation for reliability versus what he's read in the forum while doing his due diligence. Of course, people only post when there are issues -- there aren't many "things are just fine" threads.
  14. Mendel Leisk
    38,644
    Third gen owners were beta testers for:
    1. Low friction piston rings.
    2. New EGR system, that the engine DEPENDS on, to keep combustion chamber temps from climbing too high.
  15. ChapmanF
    15,435
    Once again this claim, which is always made in this sketchy way.
    One can't quite reply by saying EGR isn't there to lower combustion temps, because it is, but that is to lower the temps across the threshold where NOx emissions are formed. It is an emissions control measure.
    The implication always being made that it's something "the engine DEPENDS on, to keep combustion chamber temps from climbing too high" and doing some kind of mechanical damage, such as to the head gasket, is the part that keeps being recycled ad nauseam without any more of the homework ever being done (such as, "how close is the temperature threshold for producing NOx to the temperature limit for head gaskets", or "how did head gaskets ever survive in cars that lacked EGR and operated with temperatures in the NOx-producing range day in and day out?").
    It's true there are numerous PriusChat posts about head gasket failures. There's probably a reason for that. But it's not going to be found just by picking an explanation that sounds truthy and repeating it forever.
    Mdv55 likes this.
  16. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Seen many posts about one taxi making it over a million miles so all are bullet proof.
  17. ChapmanF
    15,435
    Well, so what's the key thing about taxis? They carry lots of passengers.
    So carry more passengers, and your Prius will make it over a million miles.
  18. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    OP. Take what you read on this forum with a grain of salt. There are several extremely knowledgeable people here, but it seems most don't know shit about cars in general and just regurgitate the same responses without any understanding of what's really happening.
    Engine running a little rough? Check your coolant, clean your EGR! You may have the dreaded headgasket issue! It's probably too late, put a new motor in it.
    Ummmm, maybe ask a few questions firs before blindly throwing out , like how many miles on it? Previous maintenance? Oh yeah, it has 180k and is on the factory plugs. Yup. Headgasket for sure, lol. Great diag guys. So helpful.
    If a lot of these posters ever bought something like a KIA their heads would spin around once those things hit 75k.
    bettergolf likes this.
  19. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I'll add that I know of several Uber drivers pounding on these cars around Boston, myself included, and there have been no headgasket issues with any of us. One guy has run multiple cars to 250k before giving them to family members and getting another.
    My car has seen 15k oil changes since I got it at 42k. It's a 2011 and doesn't burn oil, despite the "long" intervals, heavy loads, large throttle applications and "high" cruising speeds. "Conventional" wisdom here says that's all a no no for longevity :whistle:
    Threej, MexicanChip and spudnut like this.
  20. Mark10V
    Mark10V New Member
    nl
    Thanks for all the reply's!
    I kinda got the idea that the Gen 3 was inherently unreliable but like all cars it seems that with proper maintenance they can cerrtainly last.
    I'm dutch so our country is about as flat as can be, not that hot, not that cold so should be fairly soft on the battery.
    All +/v models are 7 seaters so they got the lithium battery instead of the NiMh i'll try to research what they are like.
    Like Johhny Cakes said i'm just doing my due diligence to find out about common issues.
    My current car has over 200K miles, i'm quite used to high mileage maintenance. The thing that put me off was some people on here actively discouraging people on getting a Prius or telling people to buy something like a two or three year old car, i just can't afford that.
    I'll check fluid levels regularly, and do frequent oil changes, i just don't want an inherently flawed car (say a 7 speed VW DSG).
    Again, thanks everyone.
