Is the Gen 4 Prius better than the Gen 3 Prius?
Discussion in 'Gen 4 Prius Main Forum' started by TinyTim, Dec 21, 2016.
  1. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    For Prius owners who have owned a Gen 3 Prius and a Gen 4 Prius. I am just curious of thoughts. I know there are some who think the gen 4 Prius is a radical departure in exterior design from the gen 3 Prius. I know the fuel economy is improved on the 4th generation Prius. Overall what is the opinion of Gen 3 vs Gen 4 with all things considered.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I have had a gen II a Gen III and now a Gen IV. My wife drives the new 2016 Prius and gets 10 MPG better than her 2008 Gen II. (about 54 MPG in town/stop and go - I do about 63 MPG on the freeway at about 55/60 MPH) The 2016 has a better suspension that is both smother riding and hold the road better.
    Tande, bisco and rcaine like this.
  3. rcaine
    rcaine Member
    138
    Atlanta, GA
    2018 Prius Prime
    We have a 2009 Gen III and now have a 2016 Gen IV. I would second xpcman's comments. About 10 mpg better economy. The ride and road handling is also much improved. The gas tank is also a much larger capacity which increases the range. The interior is a little bit tighter fit but manageable, only a small decrease. I do miss the glove compartment space for storage of trip essentials. The electronics/display is much more advanced in the IV.
    Tande, bisco and BLITZ XW50 like this.
  4. yeldogt
    yeldogt Active Member
    810
    313
    NE
    We have two 11's and a 16 -- the Gen 4 is better in every area. Funny -- the driver who gets the best MPG can't match the MPG with the 16 that he gets with one of the 11's. Our 11's are fives w/o the tec package and the 16 is a 4 touring.
  5. bisco
    49,371
    quieter, smoother, more comfortable seats, better mpg's, no flying bridge...
    Montgomery and Tande like this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I test drove a Gen3, a Gen4 and a Hybrid Corolla (Auris?). While the dearest of the 3, I bought the Gen 4.
    I probably would have bought a non-hybrid Ford Focus if I only had a Gen3 or Corolla to choose from.
    RCO and Prius Pete like this.
  7. ChapmanF
    15,433
    Fuel economy: advantage G4
    Ride: advantage G4
    Handling: advantage G4
    Storage: advantage G3 (G4 loses one glove box and the whole storage tray under the rear deck)
    Adding electrical accessories: advantage G3 (G1, G2, G3 all have the 12 volt battery inside; G4 moves it under the hood where you may need to wire through the firewall to add new interior circuits)
    -Chap
    RCO likes this.
  8. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Had a gen2, have both 3 and 4
    Gen 2 was body tunable, great fun
    Gen 3 is not body tunable, it's a bit of a boat, but better mpg's
    Gen 4 is already well body tuned with no braces (yet), very peppy (stronger traction battery), again better g's, its superior just Ike my latest S7 edge phone.
    RCO and krmcg like this.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Gen 4 is quieter, smoother, comfier, quicker, more fun to drive, and gets better gas mileage.
    RRxing, FuelMiser, Tande and 2 others like this.
  10. Tideland Prius
    16,125
    Gen 4 pros:
    • Better ride comfort
    • Better cornering capabilities (both grip and flatness of the body)
    • Quieter
    • More technology/updated technology
    • Nicer interior finish (soft-touch dash and higher trims get soft-touch upper door trim)
    • Better visibility around the A-pillars
    • More supportive front seats
    • Better MID graphics (4.2" TFT)
    • Better positioned (read: higher) rear door armrest and 90° fold-down rear centre armrest
    • Lower seating position for the front passenger (it's quite high in my Gen 3. Good if you're shorter but it cuts into headroom for taller passengers)
    Gen 3 pros:
    • Slightly higher seating position for the driver
    • Way more storage spaces (upper glovebox, larger lower glovebox, larger front tray, rear underfloor main bin, rear underfloor side bin)
    • It *feels* like it has more rear legroom
    • More comfortable rear seats (cushier bottom for me and what feels like a more reclined seatback)
    • USB and 12V port in the centre console box for security (but you could argue the Gen 4's exposed USB and 12V is for convenience)
    • Available solar panel ventilation system with remote A/C (Gen 4 offsets it slightly with darker factory green-tinted windows)
    • The instrument cluster looks better integrated into the dashboard design (the hood is integrated into the dash mould). The Gen 4's instrument cluster is obviously slotted into the cut-out in the dashboard.
    danlatu, DonD, rcaine and 3 others like this.
  11. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    It was my understanding that the Gen 4 fuel tank was actually smaller. 11.3 gal (vs 11.9 in prior models)
  12. Mendel Leisk
    38,644
    The G4 also deletes the centre of dash 12 volt outlet IIRC.
    RCO likes this.
  13. Tideland Prius
    16,125
    The gas tank is smaller in the Gen 4
    RCO and Bluegrassman like this.
  14. Tideland Prius
    16,125
    "deletes"
    It basically relocates one of the 12V outlets to the back and leaves the other one outside. You could say the centre one was relocated to behind the front cupholders and it's the one INSIDE the centre console box that was moved to the rear of the box.
    RCO, Mendel Leisk and Bluegrassman like this.
  15. keymusic
    keymusic Active Member
    205
    110
    Southern California
    11.4 according to the manual.
  16. keymusic
    205
    110
    Southern California
    I had an 11, 13 and 15 and now a 17. I basically agree with what everyone has said. I've gotten used to having only one glove box and no under cargo storage. The only thing I really miss about the 3rd gen are the headlights. The overall look from inside the car and the way the high beams worked was much more to my taste. My favorite thing about the 17, bedsides better mpg, is the radar cruise control. I can't imagine ever driving a car without that now.
    RCO likes this.
  17. rcaine
    rcaine Member
    138
    Atlanta, GA
    2018 Prius Prime
    I had to look in the manual on my 2009 and it does list it as 11.9. That said I don't think I have ever gotten 9 gallons in it at fillup. Most of my fill ups are between 5 and 7 gallons. We have had it since it was new so we have lots of experience. Our 2016 we got in September so not as long a history. Still we have had two 9 gallon fill ups in that brief time. Our experience has been we can get more fuel in the Gen 4 despite the capacity rating. Add the greater fuel economy and it has a much greater range.
    Rebound and RCO like this.
  18. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    We certainly all hope the G4 is better than the G3 ... most of us are confident that it is a technological achievement..
    However, the G4 has two serious reasons why I cannot consider purchasing one:
    The appearance .... a personal decision ...
    and more significantly .... ground clearance. 4.9 inches is insufficient clearance to avoid constant grounding. Here in the mountain west, we have no storm drainage, other than gutters alongside the road. My 2010 Prius grounded frequently even when I was keenly aware of the problem, and slowing significantly whenever crossing a drain (such as turning from a main street to a secondary). The asphalt directly in front of the entrance drive to the local Toyota dealership is deeply scarred and gouged from vehicles grounding.
    When I traded my 2010, the front, bottom-most (airdam) was broken, ragged and loose. I could be mistaken, but I believe Toyota corrected the situation after the 2010, then reversed the trend with the G4.
    RCO likes this.
  19. alanclarkeau
    7,044
    7,584
    Have you taken the G4 for a test drive in those situations. I'm not in country, though - but my previous car (FORD Fiesta) would scrape regularly, and I had to take speed-bumps and driveways at an angle, but my G4 I've never scraped yet in 9000km.
  20. Mendel Leisk
    38,644
    I know our previous Civic has a "South American" version, raised maybe 1/2".
    RCO likes this.
