Is the headlight switch illuminated?
Discussion in 'Prime Main Forum (2017-2022)' started by LightningBolt, Aug 23, 2020.
  1. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    Just got a new 2020 Prius Prime Limited a month ago.
    Drove it at night for the first time a few days ago.
    I couldn't see the headlight switch markings (or the fog light ones) in the dark!
    Turned the overhead map light on and still couldn't make out the markings.
    Over time this won't be a problem because I will have gotten used to the switch operation.
    I'm thinking this could be a problem if someone rented a Prius for the first time.
    Now I'm wondering if they are supposed to be illuminated and mine are faulty.
    Sooo, are the switches on the turn signal stalk supposed to be illuminated at night, or not?
  2. Tideland Prius
    16,615
    No. There is no illumination on either stalk (indicators/headlight and the wipers).
    You could either leave it in AUTO or just no that rotating the knob all the way towards you is OFF and all the way away from you is full headlights.
    jerrymildred and LightningBolt like this.
  3. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Non of my Toyota’s (and I’ve owned quite a few over the years) had illuminated headlamp or wiper or cruise control stalks.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I've never had a car in 45 years of driving with an illuminated headlight switch. Always thought that was kind of dumb.
  5. Tideland Prius
    16,615
    European cars have illuminated headlight icons but the dial itself is not illuminated AFAIK.
    But again, that's because they have a dial on the left side of the steering wheel on the dashboard.
