Is the Hybrid camry and Highlander
Discussion in 'Gen 2 Prius Fuel Economy' started by cdub1955, Apr 23, 2008.
  1. cdub1955
    cdub1955 New Member
    Lexington, KY
    using the same Synergy drive system, or are they different systems?
    Thanks,
    chris
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    The same HSD concept but a little different. Camry HSD gas engine and electric motor spin faster and then it multiplies the torque with a speed reduction unit. Prius doesn't have SRU but relies on much higher torque in the electric motor. Prius' MG2 is 295 lbs-ft but Camry HSD's MG2 is rated 199 lbs-ft.
    Highlander Hybrid's gas engine is not Atkinson cycle but the Camry Hybrid use Atkinson cycle.
  3. Tideland Prius
    16,073
    Yep they're essentially the same.
    Plus, a more descriptive title would help :)
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Also, the HyHi (or is that HiHy?) has an electric motor rear end for 4WD.
