Is the Prius a compact or midsize car?
Discussion in 'Gen 2 Prius Main Forum' started by viking31, Oct 20, 2007.
  1. viking31
    viking31 Member
    515
    22
    West Central Florida
    I was always under the impression the Prius was a midsize car. But a check on Edmunds.com classifies the Prius as a compact car. Which one is it? And what defines a compact vs. midsize automobile?
    Rick
    #4 2006
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Small on the outside, big on the inside. Except in Europe, where it's big all over.
  3. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    <div class='quotetop'>QUOTE(viking31 @ Oct 20 2007, 12:05 PM) [snapback]528165[/snapback]</div>
    Hi Rick,
    In terms of outside dimensions (length and width), the Prius is definitely a compact. E.g., it's comparable (maybe even an inch or two shorter in length) to so called compacts like the Corolla and Civic. On the inside, because of the hatchback design among other things, the Prius is comparable to the smaller end of the spectrum of mid-sized cars.
    BTW I think this topic has been discussed frequently before on this board. I think the most recent thread is linked here:
    http://priuschat.com/index.php?showtopic=38357&hl=
  4. Tideland Prius
    16,195
    For the current generation, it's a midsize. It's rated by interior volume.
    The last generation was a compact.
  5. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    It appears the EPA has taken up the torch of defining car size for fuel economy rating comparisons.
    Full size car - interior volume 120 cu ft or larger
    Mid size car - interior volume 110 to 119 cu ft
    Compact car - interior volume 100 to 109 cu ft
    Subcompact car - interior volume smaller than 100 cu ft.
    So the Civic Hybrid is a subcompact car with an interior volume of 90 cu ft.
    The Prius is also actually a subcompact car with an interior volume of 96 cu ft.
    I thought it was a "mid-size" car. Guess not!
    Oh, and the Camry Hybrid is a Compact car, with an interior volume of 101 cu ft.
