Is The Prius A Nail Magnet?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Swingshiftworker, Sep 26, 2011.
  1. Swingshiftworker
    Swingshiftworker Junior Member
    97
    San Francisco
    Is the Prius a nail magnet?
    I owned a 2006 Prius and picked up 3 nails in the 3 years that I owned it. I now own (actually lease) a 2010 Prius and have already picked up 2 nails in a year and had to replace a tire because I couldn't get off the freeway quick enough to prevent tire damage.
    I have had no nails in the low profile tires of my MR2 Spyder that I've owned for over 5 years. One nail in a nail in 4 years in the FJ Cruiser that I owned and recently sold. And one nail in the Ford F250 that I've owned for 3 years.
    Based on this experience, it seems like the Prius gets more than it's fair share of nail punctures and I'm curious whether other people have gotten them as frequently as I have.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I do not know about being a magnet but I had a screw imbedded in one of my tires for the first time in years. It ended up causing me to purchase new tires prematurely.
    52,679
    i have not had a nail/flat for probably 20 years. i used to get them all the time in the 70's in my mg. do you live in a high building/remodeling area?
  4. fuzzy1
    10,662
    Not mine, nor any cars in my household. Nearly all flats of the past decade have been on the household's bicycles.
  5. offroader
    offroader Junior Member
    44
    Must be caused from the electric magnet in the motor:mod:
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I find the driving route has more to do with it then anything else. If you are close to a trash dump or travel the roads leading to it or the same thoughts for construction zones (home or commercial), you are more likely to pick up nails.
    Tire law: the more expensive and new the tire, the more likely to get a flat. :)
  7. MariaEvri
    MariaEvri Member
    122
    Limassol - cyprus
    holy **Swingshiftworker, I was thinking the exact same thing yesterday when I had a flat tire-from a nail
    AGAIN
    I had my car fir 3 years and I had a flat tire (from nails) 3 times
  8. DavidA
    2,349
    1,825
    Chicago western burbs
    Two Toyo Proxes tires in first ~5,000 miles. One was shredded from a hunk of metal in Ohio and the other was a nail and was (mostly) fixed by the dealer, but it won't last the same life as the remaining two - unless - those last two get nailed too. No problems the last 10K though.
  9. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Just stop driving over nails! Problem solved.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    What mechanism could possibly explain one car being more prone to nail punctures than another? More likely that the driving route or tires are responsible.
    Tom
  11. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Even if all other things were the same, this is hardly statistically significant.
  12. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Way back in the days of Le Sabre, Monte Carlo, Chevette, K cars and such I was told underinflated tires would be less likely to pick up a nail/screw but more likely to work in an odd piece of scrap metal or plastic (actually had a piece of plastic that looked like metal trim wedged in a tire once).
    I haven't picked up a nail or any sort of road hazard in years and years. I do pick up that little gravel that likes to wedge in the tread of the tire but I just take my house key and pry them out every once in a while.
    I think tire pressure plays a role but where you drive and whether or not the city sweeps/cleans the streets matters more.
  13. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    Try driving around on the Gulf Coast after a major hurricane when everyone is having their roofs repaired or replaced!!!!
  14. youdontsay
    youdontsay New Member
    29
    east of the Triangle, NC
    Well ... I hadn't had a flat tire for eight years and then got three in the Prius in the first 18 months. Two of them were nails; one of them was a massive crater in the road that was totally my fault. :rolleyes:
    I'm not sure if that's just bad luck or what ... I'm due for new tires very soon, so we'll see what happens after I get new ones. :eek:hwell:
  15. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I had 3 nails in 2 months, but then, I have a lot of enemies.
  16. DavidA
    2,349
    1,825
    Clearly, we can see where this thread is headed. The Prius is a nail magnet. No scientific survey needed. ;)
  17. Eoin
    Eoin Active Member
    593
    116
    Long Island
    No, but it is a chick magnet.
  18. DavidA
    2,349
    1,825
    That's a whole new thread.
  19. ursle
    ursle Gas miser
    1,049
    192
    NH
    Ah ha, to many coincidental nails, sounds like subterfuge, need to make the rear camera motion detecting, web friendly, sound enhancing, all knowing, night vision enabling, police alerting and gun shooting...
  20. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The best explanation that I have seen yet is running higher tire pressures. I know I run a much higher pressure on the Prius than I have for any other car I have owned.
