Is the Prius dangerous?
Discussion in 'Gen 3 Prius Main Forum' started by johnjeric, Mar 19, 2013.
  1. johnjeric
    johnjeric Junior Member
    Hey all!
    I just recently got my first Prius and am completely loving it!
    I had two concerns however:
    1.) Is the Gear stick designed dangerous? I ask because you can easily change from D to R with just a simple "slide" or "push" of the gear. This causes concern on the freeway. Did Toyota install a safety feature in case a passenger accidentally hits the Gear into Reverse on the freeway at high speeds?
    2.) Also, since the Park Gear is in a Button, what if this was accidentally pressed on the freeway?
    Thanks Prius enthusiasts! :)
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you are going over about 3 MPH, both R and P beep at you and put you in N. This is actually faster than selecting N, so if any Prius driver actually DOES have unintended acceleration, it is a quick way to get in N. Hitting the ACTUAL brake, instead of the one you think you are pressing, also works.
    Based on statistics, Prius drivers are about half as dangerous as drivers in general. (You could try to claim it is the cars, but I doubt it)
  3. Rainking
    Rainking Member
    162
    Johnson City, New York
    Going from D to R more than a few mph will result in no action so concern 1 is not an issue. Concern 2, again nothing at highway speeds. Only N works in highway speeds.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I recall that software protects the car. Perhaps someone can chime in.
    One person thought the P for park was P for power mode, so he was accelerating on the freeway on ramp and hit the Park button. Nothing happened. I believe he was put in neutral
    ralleia likes this.
  5. bisco
    49,401
    and since the shifter returns to the neutral position after selecting d or r, you can't accidentally bump it from one to the other anyway.
  6. RaZa
    RaZa Member
    480
    93
    BEWARE! This is what happens if you push any of those buttons.
    AllenZ, retired4999, Rainking and 3 others like this.
  7. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    I've managed to inadvertently knock the dome lights into 'on' position, but never the shifter on the Prius.
    On my former vehicle ('94 Chrysler LHS), the shifter was a manual located on the center floor in a much more vulnerable location. On a few occasions over the course of a decade I managed to bump that (usually with a bookbag or briefcase) from drive into neutral.
    Led to momentary confusion as to why the engine was revving without torque, but quick, embarrassed recovery with no damage, even with a comparatively low-tech vehicle.
    I don't anticipate any issues with the not-too-low and not-too-high position of the Prius shifter.
  8. JMD
    3,779
    1,282
    Now this is dangerous, don't try it with a Prius.
    stans likes this.
  9. ralleia
    386
    137
    I'm not gonna try that with ANY kind of vehicle!
    Except maybe a bounce house...
    JMD likes this.
  10. JMD
    3,779
    1,282
    I would like to see the drivers face when he stopped and looked at the grill and noticed he killed Bambi
    ralleia likes this.
  11. ralleia
    386
    137
    I would HOPE that he noticed when the thud occurred and when the radiator lost all fluid.
    If it were me I'd have been on the cell phone immediately calling the sheriff for a non-hunting deer tag and the meat processor to make Bambi into neat little freezer-wrapped packages.
    Still wouldn't cover my deductible however.
    Needless to say it wouldn't be the first time that I was in a vehicle involved in a deer collision...
    JMD likes this.
  12. JMD
    3,779
    1,282
    Well the good news is you didn't hit a Cougar.
    BCP, cwerdna, xs650 and 1 other person like this.
  13. fuzzy1
    10,166
    Of course it is dangerous. It is a motor vehicle, and motor vehicles are dangerous.
    But your gear shift concerns are nothing to worry about.
    There is an action on both concerns: the car goes into Neutral with a double beep warning.
    There is no damage. In this case, the software is smart enough to protect the car.
    F8L likes this.
  14. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    While it did not turn out well for Bambi or the vehicle, I do hope the driver and passengers were OK.
    But let me ask this: How did the deer get "under the hood" in the first place?:eek: And it "tried" to tunnel out through the grille?:rolleyes: Tell me the driver did not hear any "knocking" and "pinging" under the hood before the critical moment that he realized he not only had horsepower but deerpower as well...:ROFLMAO:
    JMD and ralleia like this.
  15. bwilson4web
    15,513
    Welcome to the world of Prius:
    We are actually 'driving' computers with chip resident software that operate the car. Furthermore, the transaxle is special, as there are no 'gears' that shift positions.
    The transaxle has no clutches or torque converters. Instead, two computer driven motors and a planetary gear 'change' the effective gear ratio. It is all but impossible to trick the computers into doing anything destructive. For example, there is a 'parking paw' that is activated by a computer controlled motor. The computer will not engage the paw if the car is moving at any speed faster than a slow walk.
    For good measure, try to break it or better still, go of a test drive in a dealer Prius or rental and try to break it. At say 25 mph, try to abuse the shifter and "P" . . . then have fun with your Prius-skeptic relatives. <grins>
    Remember, April 1 is coming soon.
    ralleia likes this.
  16. Zythryn
    Zythryn Senior Member
    6,237
    4,236
    Yes, the Prius is dangerous.... to OPEC :)
    Never experienced any of those issues in the time we owned either of ours.
    sdtundra, Silver bullit and JMD like this.
  17. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I'd hit that Cougar:whistle: Sorry, couldn't resist...
    BCP, xs650, JMD and 1 other person like this.
  18. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, apparently I'm an idiot. Driving in the city at about 50 km/hr (30 MPH) Pearl S coolant was getting warm enough for the heater to be turned on. Hit "P", car beeped, lights came on on the dash, car went into "N". Put it back in "D" without stopping, then tried again, again hitting "P". Sigh! On my -third- try I actually turned on A/C auto, my original intention.:love:
    So no, the shifter is not "dangerous".
  19. hlunde
    hlunde Member
    419
    74
    I would say that it's not dangerous. The only feature that is truly annoying to me it the delay going into neutral since I like to shift to neutral when I'm waiting at a traffic signal when people are crossing right in front of my vehicle.
    But, to me, the Prius gear selector layout is simply ridiculous; it's a novelty and not an improvement over the standard PRNDL (PRNDB) ---- except that it saves center console space. I am not a full-time Prius driver and drive a variety of vehicles each week. This may have something to do with my perspective.
  20. Jonnybegood
    Jonnybegood New Member
    29
    Clark's Summit, PA
    2013 Prius v wagon
    Good info! Will share it with my wife who has some concerns :)
