Is the ScanGaugeII still the one to get
Discussion in 'Gen 2 Prius Main Forum' started by blfuller, Mar 26, 2018.
  1. blfuller
    blfuller Junior Member
    25
    Eastern Washington State
    I'm considering getting the SGII now that I had to take my '09 into the Stealer to get the check engine light code read. DTC was P1116 & P1121 which means the 3 way valve needed replaced. I have 144K on it now and I am going to get one so I don't have to go in anymore and self diagnose. The Stealer wanted $950 to replace the valve because they had to remove the front bumper. Yeah, right. The TSB says it should only take 2.1 hours.
    Anyway I see there are a few others out there and I was wondering if the SGII is still the one to get or is there something better. Any input would be appreciated. Thanks.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    If you have a laptop, get a mini-vci cable with toyota techstream ($20 or less).
    If you have an android product, look into the 'Torque' app. Not as fully functional as Techstream, but it has saved me a couple of time while driving when a bunch of lights appeared on the dash (maybe $5).
    Raytheeagle likes this.
  3. blfuller
    25
    So this mini-vci cable is Toyota specific, correct? Copy of the Toyota Mongoose if I understand correctly. Are any one of these better than the other?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    The scan gauge is more of a universal obd tool. It’s ok but it does not have TIS software.
    I highly recommend to own it in general as you can pull codes on any car.
    There’s the mini vci or there’s also VXDIAG with Toyota techstream for $99.
    Amazon.com for VXDIAG. Works good plug and play Win7. They will return your emails too.
    I have all 3. I had the ScanGauge for about 10 years and then few years back sent it to them and they upgraded it to a Xgauge. Long lasting tester really.
    Linear Logic likes this.
