Is the tank completely full ?
Discussion in 'Gen 3 Prius Fuel Economy' started by rich s, Apr 30, 2012.
  1. rich s
    rich s Blackie II The Prius
    N. California
    When the car leaves the dealer was the tank holding all 11.9 gallons of gas ? That is minus the twenty miles worth on the odometer. I am trying to figure out my mileage after my first fill up. I am wondering if there was a full tank , or perhaps a little less for transport? Is it filled at the dealers or before it is shipped?.....Thanks ....Rich
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The first tank is always suspect. It isn't uncommon for the "full" tank to be somewhat less than full.
    Tom
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    When you get gas and the pump clicks off on auto
    you can still nurse in another 2 gallons of gas
    in the tank until the tank is completely full
    with standing gas at the filler nceck.
    The real tank capacity is 13.5 gallons or so when
    filled in this way...
  5. bisco
    51,141
    did you have all the pips?
  6. fuzzy1
    10,335
    It has some fuel before shipping, but is not filled until after it reaches the dealership. Generally a lot attendant takes it to a nearby fuel station as part of the final prep. There is absolutely no control for consistency.
  7. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Nope; the tank is 11.9 gallons FULL to capacity.
    Moreover, it's literally bad for your car to fill the tank up past the click as it can cause damage to evaporation system bits. At least that's what I've read. And it sounds an awful lot like an urban legend, so I tried googling but cannot find anything conclusive either way. I'm in fact inclined to think it's not true, but who knows :)
  8. El Dobro
    El Dobro A Member
    7,075
    3,258
    The only way you would have gotten a fairly accurate figure on fuel mileage when you left the dealer is if you reset the trip odometer and started from there.
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I remember reading somewhere in this forum that
    when filled from nearly empty to the top
    of the filler neck it was over 13 gallons.
  10. qbee42
    18,058
    3,076
    Northern Michigan
    Skoorbmax's point is that 11.9 gallons is the rated gross capacity of the tank. You can exceed the rated capacity by filling the filler tubes and other nooks and crannies, but it is in excess of the rated capacity and may have detrimental effects. Many drivers do it routinely without apparent problems, but every owner's manual that I've read specifically cautions against over-filling.
    Tom
  11. fuzzy1
    10,335
    I remember reading the same thing, multiple times.
    But I've also failed, on several attempts, to achieve anything close to that. When trying to pack in extra fuel on long trips where the overfill will be burned off immediately, my filler tube has filled up with less than a third of the 'extra' fuel others have claimed.
  12. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have checked the owners manual for our 2010 Prius
    and there is nothing stating about filling the tank to the
    top of the filler neck.
    Perhaps the newer owners manual for the 2011 and 2012
    Prius have that mentioned...
  13. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    So as far as everyone knows, filling the tank to the top does not hurt the "so called" evaporation filter or what ever they call it. I would like to see a diagram, or some sort of drawing of what is connected to the filler tube so we can see for our selves.
    John
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I agree, if it was so important the issue would be
    certainly addressed in the owners manual.
    I know Wayne Gerdes from cleanmpg.com when
    conducting his mpg test he fills up to the neck
    for consistentency. I don't recall him stating
    that this practice will cause severe engine damage.
  15. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I agree but I still don't over fill. I feel more comfortable not overfilling and when I use to while back before I owned my first Prius it was easy to have gas drip over onto the ground when removing the nozzle.
  16. WE0H
    WE0H Senior Member
    3,247
    528
    I lost a pip around 54 miles. No way it was full. It's been a while since I drove a rental Prii, but I believe it should go about 125-145 miles before it looses the first pip. I only have 91 miles on my car so I am nowhere near ready to fill her up :p
    Mike
  17. walter Lee
    1,126
    376
    Maryland
    The argument I've read is that there is a risk that dirty gasoline might eventually clog up (with residue scum) the gasoline vapor pressure/overflow release valve(s). The arguement continues that inside the fuel tank, there is a fuel pump which pumps the gasoline to the gas engine up front. If the vapor pressure/overflow release valve fails to work properly and gasoline tank experience abnormally high pressure levels then the fuel pump inside fuel tank would experience increase work/stress loads which could cause it to fail prematurely.
  18. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Basically when you fill the tank, there must be someplace to put the >10 gallons of hydrocarbon-saturated air which is being replaced by liquid fuel. At the highest point of the tank is a vent which is connected to the charcoal canister. The HC-saturated air is fed through the charcoal canister, which adsorbs the HC's from the air. From there, the "purified" air goes through a tube, usually to somewhere near the top of the filler neck, in case you are at a gas station that has vapor-recovery systems in their nozzles (most don't these days). There are a bunch of solenoid valves that control where the flows go.
    When you start driving again, the system directs fresh air through the charcoal canister, which releases the adsorbed HC into the fresh air. The resulting HC-laden air is directed into the engine's air intake, richening the mixture a bit. The carbon is now regeneraed and ready for another fillup.
    When you overfill, the extra gas goes up through this system, which causes several problems: (1) the volatile components of the fuel are present in very high concentration, which will oversaturate the charcoal, (2) less volatile components which normally don't come into contact with the charcoal may bind irreversibly to the charcoal, "poisoning" it.
    If the canister is toast, you are releasing HC pollutants to the atmosphere when you refill, only you don't have any way to know that. If you are lucky, the system won't throw a code. If it does, repairs may be expensive.
    This question comes up all the time. I just fill to the first click, no worries.
