Is there a case for cabin air filter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Aug 17, 2020.
  1. berderder
    berderder Junior Member
    69
    Connecticut
    Hi all,
    See photo below.
    Isn’t the cabin air filter supposed to fit into a caddy that tightly fits into the compartment? Not supposed to be loose? I can’t find any such item online. It even seems normal according to some videos
    51,154
    not sure what you mean, it looks like most any air filter, and they are easy to find. the cover unhooks from the front, pull the old filter, insert the new, replace the cover.
    i got one on amazon.
    adecent filter will fit well, some knockoffs will not.
  3. berderder
    69
    Connecticut
    I guess that’s what I mean is that it’s so loose, seems like it’s supposed to be placed inside a special tray and slid in? The previous filter was also loose like this and I think was installed by the dealer. So...I’m not really sure why it looks so loose. The current one is off brand
    51,154
    no, no tray. doy you have the old one? does it say toyota?
    berderder likes this.
  5. berderder
    69
    Connecticut
    After looking into it, it seems maybe it is that way because of the airflow. Not too tight, not too loose. I don’t know, that’s my best guess. Unfortunately no I don’t have the filter still. It may have been installed by dealer I bought from
  6. bisco
    51,154
    yeah, it's not a snug sealed fit like the engine air filter
  7. AzusaPrius
    AzusaPrius Senior Member
    2,137
    904
    Wrong air filter for sure.
  8. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    I’ve changed cab filters on other line of Toyotas they’re all like that. If the fit was any tighter, filters be ripped left and right or be stuck like oil filters.
  9. bisco
    51,154
    yeah, hycam is the same
  10. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    No caddy on the Gen III's. Old filter out, new filter in...
    Fostel and berderder like this.
  11. AzusaPrius
    2,137
    904
    Good thing I looked at mine because it was dirty but looking at it seems the K&N filter has rubber sides so it sits tighter and seals better. 20200818_154847.jpeg
