Is there a difference in weight of OEM 15" wheels?
Discussion in 'Gen 3 Prius Fuel Economy' started by dynasty, Nov 6, 2014.
  1. dynasty
    dynasty Member
    153
    26
    northern NJ
    ive owned two 2010 Gen III prius and my first car was averaging 52mpg easily.. the second car i cant seem to get over 45mpg. my driving style is the same.
    When i removed the wheels from my new car it felt much heavier than the car i had before.
    the only difference between the two 2010s is that one is an earlier model than the other.. some minor mods includes the USB port and the tires are different.. i had yokohama Avids on the first one and my current car has Ecopia tires.. do you think the tires are the main reason for the drop in MPG? thanks
  2. Mendel Leisk
    40,586
    Maybe has something to do with that software recall, to protect the inverter? Some owners had no problems, others had significant mpg drop.
    Kinda doubt it's the tires. What Ecopia? EP20?
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I agree with Mendel, it's not the tires or the wheels. The Ecopia EP20 is just as afficient as the AVID S33D. The wheels are the same weight. Wheel weight wouldn't cause such a loss in fuel economy anyway.
    Do you notice the engine running more often than it should (after it has warmed up)? I.e. While sitting at a stoplight with the AC and heater off?
  4. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    trying to guess why mpg is lower in one car than it was in the other?
    What was the mpg of both when you got them?
  5. Mendel Leisk
    40,586
    You might be a good candidate for testing the vagaries of mpg, post inverter software update. Cold comfort I guess.
  6. dynasty
    dynasty Member
    153
    26
    northern NJ
    It could be software. I read going higher in tire pressure. 36/34 lbs. might help. whereas I was running 32 all around. I have my 18" wheels on at the moment but I want to test with the stock 15's. With the higher tire pressure.
  7. dynasty
    dynasty Member
    153
    26
    northern NJ
    The mpg on my first car on stock wheels was easily over 52mpg and my new car is about 45mpg. No matter how much I hypermileage I can't get it higher than that. This is based on running a full tank or so in Eco mode. With my 18's. And they are super light volks I can only muster 43mpg.
  8. Mendel Leisk
    40,586
    What make/model/size tire?
    They're very likely dropping your mileage.
  9. tv4fish
    tv4fish Member
    202
    46
    That could be PART of your problem - most of us going for high mpg will go higher than those tire pressure - I run 40 front - 38 rear.
    I can assure you that will help on your mpg.
  10. Mendel Leisk
    40,586
    ^ That tire pressure Dynasty mentions is maybe with his 18"? Toyota's recommendation is 35/33 (front/back) with 195/65R15, but 33/32 with (optional) 215/45R17.
    FWIW, I run our 215/45R17 around 36~38 all around. But the ride is progressively stiffer/harsh with the lower profiles.
