Is there a forumla to know the cost for each Empty-Full EV charge?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Apr 25, 2017.
  1. stevepea
    stevepea Senior Member
    533
    581
    Is there a formula, where you could easily plug in (pun intended) whatever number your local utility charges for the electricity, to figure out how much it costs to do a full charge from empty to full?
    For instance, if the electricity cost is 17c, then what would a full charge cost? (Doing it overnight while you sleep, going from typical depleted to full)
    Thanks!
  2. bwilson4web
    15,561
    6.4 * 17c
  3. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    Is it 6.4 KWh useable for EV? I was guessing more like 5.5-6KWh, once you subtract out charging overhead and HV-operation space...
    iPhone ? Pro
  4. bwilson4web
    15,561
    I measured it: Prius Prime Plus in my hands | Page 7 | PriusChat
    Correction 6.3kWh for a full charge in Rhode Island and 6.35kWh in Huntsville AL.
    #4 bwilson4web, Apr 25, 2017
    mr88cet likes this.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    I only measured it once, but it was 6.6kWh (from L1) that one time.
    bwilson4web likes this.
  6. bwilson4web
    15,561
    @Lee Jay brings up a good point that there is some variability both in the battery, charging conditions, and systems making the measurement. So I am confident that 6.4kWh is a perfectly fine and usable value. It is subject to variability as someone pointed out that slower charge rates are less efficient that faster ones.
  7. Lee Jay
    5,850
    4,024
    It's also variable based on the amount of hybrid-charge left in the battery when you shut off the car.
    Prius from Dad and bwilson4web like this.
  8. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    I recorded 6.41 kwh using a 120v evse metered thru a kill-a-watt meter once.
    Excellent point about charge left in hybrid portion of battery.
    our electric rate is 0.11/kwh with taxes, so a full charge of EV portion of battery costs about 70 cents at home.
    priuscatprimeguy likes this.
  9. bisco
    49,693
    are the ~15% charging losses included in the 6.4 figure?
  10. bwilson4web
    15,561
    Yes although the losses vary by the voltage:
    • 240 VAC - home EVSE @16A (lowest)
    • 210 VAC - business EVSE @16A
    • 120 VAC - home EVSE @12A
    • 120 VAC - home EVSE @8A
    #10 bwilson4web, Apr 25, 2017
  11. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    try this, I think this does what your looking for
    MPGe Cost Comparison Calculator
    mmyk72 likes this.
  12. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    The losses do not play a role in the electricity cost. You are buying both the energy used and the energy lost.
  13. mr88cet
    2,311
    1,334
    Austin, TX
    I gather the OP's goal is to get a handle on the total cost, including charging in/efficiency.
    iPhone ? Pro
  14. drysider
    823
    332
    Liberty Lake WA
    The total cost is what you take from the mains. It includes eventual losses. Of the 6.5 kwh you probably get 5.5 kwh or so in useful energy, but you pay for 6.5.
    giora likes this.
  15. Lemooron
    Lemooron Junior Member
    73
    25
    Lemoore, CA
    I have charged with 0 miles left 4 times 6.48 - 6.35 - 6.50 - 6.39 for an average of 6.43
  16. drysider
    823
    332
    Liberty Lake WA
    Informed data is a great thing.
  17. CharlesH
    2,787
    1,152
    Roseville, CA
    One of the reasons L1 charging is less efficient than L2 charging is due to the losses in the charger electronics, which are more or less constant per unit time, but L1 charging takes more than twice as long as L2 charging, due to the voltage difference and since at 120V, the car only accepts 12 amps, but accepts 16 amps at 240V.
  18. Lee Jay
    5,850
    4,024
    They're more likely to be constant per unit time only if current is constant. Lower current will have lower losses.
  19. bwilson4web
    15,561
    I used th think the same until I looked at switching regulator data sheets.
    fuzzy1 likes this.
  20. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    At 240V the charge from the wall (payable energy) is only about 6 kWH as reported by @GT4Prius
