Is there a minimum Life Expectancy to do Balancing ?
Discussion in 'Prius c Main Forum' started by Isaiah De Freitas, May 10, 2024.
  1. Isaiah De Freitas
    Isaiah De Freitas Junior Member
    Trinidad and Tobago
    2016 Aqua
    I have a 2016 prius c and a technician in my area says he does not balance batteries that have less than 60% life expectancy because there were instances where the battery faulted after the process. But other technicians say it is fine.
    Now i have 58% LE on my car and I bought a Maxx Volts balance charger and would really like to start balancing my battery but I am very unsure now.
    Do you think it is a case where I should just balance once instead of thrice as said in the manual? or is it a matter or dropping not less than a particular voltage when discharging and I should be fine ?
    Please help!
