Is there a plug & play speaker upgrade?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by rewing, May 23, 2024.
  1. rewing
    rewing New Member
    Vancouver BC Canada
    In my last car (Dodge Dart) I upgraded the stock paper speakers to the Mopar "Kicker" (brand) plug & play plastic speakers and it sounded 10x better with no other changes to the audio system.
    Is there a Toyota Prius Gen 2 speaker package upgrade kit? Was there? Or is there a known perfect fit option? I liked that I didn't have to do annnnny wiring or soldering or anything - the connections were all prefabbed so you just literally plug them in and put the mounting screws in and covers back on. Is there anything like that for these cars or highly recommended upgrade options people have pieced together and are tried/tested/true ?
    Last thing I want to do is buy anything that doesn't fit or is a major pita to try to make work/have it not work and discover I need to buy a new head unit or amp or some other bs. Car is a 2006 RHD "Touring," from Japan if that makes any difference.
  2. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    I don't know of a kit, but on the other hand they are a common size and it isn't hard to find replacements that use the same push-on connections.
    The toughest thing to deal with is the fact that the stock speakers are riveted in, which is an excellent inexpensive way of making sure they don't rattle or buzz.
    The downside is that you aren't getting the factory speakers out until you drill out those rivets. It isn't hard, but it isn't snapping-a-kit-together easy either.
    Crutchfield.com has a wonderful database of how well given speakers fit. Even if you don't buy from them, they've got good info.
    I upgraded our Prius with a set of Infinity 6532ex speakers six years ago. Huge improvement. Not sure if the same speaker fits your version of the Prius, but worth checking.
    Good luck!
  3. rewing
    rewing New Member
    Vancouver BC Canada
    Hmm.. that website might be helpful but not nearly as helpful as a specific upgrade kit made for this car so you could just buy it.
    There are 178 results for a 2006 Prius.. and each one for a different speaker location etc, so then you really have to know speaker stuff to figure out which ones to get that work with each other in all the right spots.. and what type of connectors they have vs. what the car has/what parts to buy.. and whether you need to figure out any other mounting hardware to buy.
    Hmm.. this is definitely not a 2-5 click purchase. More like need to consult someone who knows anything about this stuff for their input on what to buy and why so I can have all the bits to put them in vs. buy one of those and 2 of those and then wait for shipping and then find out I need to buy electrical connectors from Japan and have some mounting brackets 3D-printed etc.
    Also, the website asked if it has factory navigation maps because I guess somehow this makes a difference to speakers ? The car does have factory maps in the display, however, it's a JDM car with JDM head unit and maps of Japan. No idea if any of that makes any difference to which speakers will fit and work ? Hmm.
    I <3 plug & play! haha
  4. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Yep. I'm surely not aware of a one-shot kit, and certainly not one that anyone has bothered to keep in production 15 years after the 2G cars stopped being made.
    If you need a 2-5 click purchase, buy a beats pill or sonos soundbar, plug it into the 12v outlet, pair it to your phone and you're set.
    If you want something more built-in than that you'll need to invest some time and thought.
    I would say though, a JDM car is going to be trickier because they have different options and different wiring, so USA-based guides won't help much. Might be better off sticking with a wireless appliance.
    Good luck!
    #4 Leadfoot J. McCoalroller, May 29, 2024
  5. rewing
    rewing New Member
    Vancouver BC Canada
    Uuuh, plugging a speaker into an outlet != car audio solution at all as all of the built in speakers would still be oem junk. Only time I used some totally separate speaker was in an old VW rabbit with no radio. I bought a $12 AA battery powered single speaker FM radio from London Drugs and taped it to the dash. :p
    2-5 click speaker upgrade purchases exist. I bought the front kit & rear kit for my last car that way. Plug & play connectors, too. Dodge put out speaker upgrade kits that worked for multiple vehicles that had the same size speakers. Apparently Toyota hasn't considered that people might want better than paper without buying a Lexus. Was hoping they had so I could seek, ideally, a new-old-stock kit and just plug it in boom done.
    Even if I had a North American car that website still has tooooons of options, including different sized speakers specified for the same spots.. not exactly sure how they figure they fit if they're a 1/2" different in size. Guess I'm going to have in ask car audiophile ppl what will work and what to buy etc as the current ones are mediocre at best and I'd rather have something better considering I tend to drive ~100-120km/day and like listening to music or whatever on the highway that sounds decent w/o costing thousands of dollars. A ~$600 speaker upgrade worked MIRACLES in my last car, so figure if I spend a similar amount of money on speakers for this one it'll likely be a very big upgrade over existing.
  6. Aloe
    Aloe Junior Member
    55
    Canada South
    I also have a JDM. I think the only consideration is if your stereo has built in amp or an external amp. They all have built in amps in the head unit unless your have a JBL system, those ones have external amps. On my non JBL unit, I changed out the head unit to an Android unit and it works fine. My next upgrade is to get semi subs (8-10" woofers) or subs (12") as bass sound is sorely missing.
    If you look through the threads, there is a PDF writeup on installing speakers for the car, it might clue you in as to the dimensions of speakers you should be looking for (the depth measurement will be critical). There were some examples from the thread of people that changed out just the speakers with little to no modifications (but be prepared to if necessary especially for the tweeter portion AFAIK from my research). I don't spend much time in my car (maybe 5miles a week). If I were you, I'd get on about upgrading; even just upgrading the head unit for the basic functionality of the full North American radio spectrum is a godsend.
  7. Aloe
    Aloe Junior Member
    55
    Canada South
    I often thought of this solution. They make wonderful little portable unit that pack a punch, some can even be wirelessly connected together to act as one unit (stereo even) so you can have one in the back seats as well. I was thinking of cheap "Soundcore" units from Amazon. Really, everything in one, even has serious bass (compared to stock), BT ready.
  8. rewing
    rewing New Member
    Vancouver BC Canada
    Do you have a link to any threads with speaker replacement details/sizes/instructions?
    I hadn't thought of replacing the head unit. Not sure what one from what country would be compatible with my car and Zero clue how to go about changing it. I don't even know if the JDM car has the same ECU has the North American one -> I do know that some cars have different ECU's in different markets so would need parts compatible with whatever is in it.
    But you're right, it would be nice to have the full North American radio frequency spectrum available vs. having to bluetooth stream one station from the RadioPlayer app via a bluetooth FM tuner thing plugged into the outlet inside the armrest storage area.
    If instructions aren't crystal clear I might have to wait until I have a bunch of more important things off my to do list and find someone familiar with this type of work and pay them to do it all.
  9. Aloe
    Aloe Junior Member
    55
    Canada South
    From what I gathered, changing out the speakers isn't going to do much. The better upgrade would be to add a sub. I bought a used sub but won't get to installing it anytime soon; waiting on some other parts and some spare time to install. I'll give my feedback then.
    Regarding the head unit. All you need to know is if you have a JBL stock unit or not. The JBL units will have a JBL logo on the head unit and the tweeter cover portion of the speakers on the doors (front of side windows). Nothing to do with ECU.
