Is there a Scangauge or an alternative with a bigger screen?
Discussion in 'Gen 3 Prius Technical Discussion' started by vahrn, Aug 31, 2010.
  1. vahrn
    vahrn New Member
    66
    Parma, Italy
    Hello,
    I would like to purchase a Scangauge II for my Prius, but I'm a bit disappointed by the amount of info you can display simultaneously (4 gauges) and its readability. Is there something bigger which could serve to the same purpose (and thus being programmable with Xgauges) but bigger?
    Thanks!
  2. gbarry
    gbarry Junior Member
    79
    16
    S. California
  3. nerfer
    nerfer A young senior member
    2,505
    233
    28
    Chicagoland, IL, USA, Earth
    You can also chain a couple ScanGauges together. But a more user-friendly screen like some of the larger devices offer would be nice.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    There is a new multi-gauge on the market that has a larger screen than
    the ScanGuage and costs about 1/3 as much, $60...
    However, it does not have the capacity for hybrid/Prius specific
    readouts like the ScanGauge's XGauges.
    Enter the Ultragauge
    There is an ongoing discussion about this gauge package at cleanmpg.com.
    Summary: Better displays -- maybe SG will now finally move beyond
    it's Atari-era display at last :p -- but it does not have the ability to
    identify and display hybrid specific data.
    Bummer. :(
    IIRC, the DashDaq has roughly the same problem: great multi-color,
    programmable display, but cannot display hybrid specific data... $400.
    Drat! :mad:
    2 people like this.
  5. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    I use the Canview V4, it uses a big screen. You can also get the Canview V3 to use with your existing MFD screen. It is pricy but you get what you pay for. It makes the ScangaugeII look like crap.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    CAN-View is no longer sold for Prius that do not have the PHEV conversion.
  7. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is hope for a low cost functional alternative. pEEf (do a search on PC) is designing a new OBD2 unit for his Gen2 Prius. His plan is to do firmware for the Gen3 soon after he finishes the design.
    JeffD
  8. hatbe
    hatbe Junior Member
    San Jose, CA
    Hi Rokeby!
    I'd like to buy a scanner for my Prius, There are 2 option for me: scan gauge II and ultragauge, can you elaborate this?
    Thanks,
    HB
  9. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Take a look at Torque on an Android phone or pad with a bluetooth OBD2 adapter.
    JeffD
  10. walter Lee
    1,126
    376
    Maryland
    You can daisy chain several ScangaugeII display units together
    with RJ45 Cat5E network (patch panel) cables. Each ScangaugeII
    has two RJ45 sockets one in the rear and one on the right side.
    This means you can add in increments of 4 gauges. The real
    advantage to staying with the ScangaugeII is its support
    for the Prius' special hybrid system via its Xgauges. Pricey at
    $160 per 4 gauge but maybe you could get a group discount?
    There are OBDII/CAN scanners that connect to a computer
    via USB port which in theory you might customize to display
    the info you wanted onto a bigger display. These devices are
    inexpensive - but the programming to make it work would
    probably be intense gearhead stuff. :rolleyes: Some states
    have restrictions as to what kind of displays you can
    have on the driver's dashboard. While the Scangauge II
    is very small - a larger display might attract some attention.
    While most laws like the one in MD permit displays used
    to assist in driving - that doesn't mean a state trooper might
    not pull you - just to check it out....
