is there a setting to keep TracBatt between 15-85% to extend Batt Life?
Discussion in 'Prime Fuel Economy & EV Range' started by The Big Sleaze, Jul 28, 2024 at 5:29 PM.
  1. The Big Sleaze
    287
    63
    'frisco
    2020 Prius
    Two Eco
    My "new" renewed Samsung Note20 Ultra's setup included asking me if I'd like to set it to keep Battery between 15-85% to extend Battery Life.
    I remember Scotty Kilmer saying same should be done with E-Cars (or PHEVs). Is the a setting on a 2020 Prime to do that?
  2. pasta4breakfast
    pasta4breakfast Junior Member
    56
    24
    Southern California
    2020 Prius Prime
    I think Toyota automatically sets the traction battery to charge only between 15% to 85%, though the exact numbers are unknown. The battery size is 8.8 KWh. If you charge it from 0% to 100%, I doubt you will ever be able to add more electricity than 6.5 KWh. I have only been able to add about 5.3 to 6.1 KWh when charging from 0-100%. That means about 30% of the battery is off limits for the EV mode, some of it is a buffer at the bottom for the HV mode and the other is a limit for the top to protect the battery from being fully charged.
    49,526
    toyota takes more care protecting your battery than phone companies, because cali forced them into a 10 year warranty
    pasta4breakfast likes this.
