Is there a timing belt in my Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by Yordan, Sep 11, 2014.
  1. Yordan
    Yordan New Member
    Surfside beach
    Is there a timing belt and when is the recommended to be replaced?
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    No, it has a timing chain.
  3. Yordan
    Yordan New Member
    Surfside beach
    So, I don't have to change it as far as I know about chains, right?
  4. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Timing chains have a long life and make sufficient noise before failing to warn you to maintain them.
    JeffD
  5. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    In Prius it will probably outlive engine itself. And engine if well maintained will probably outlive the car. Low oil level will shorten both the chain and engine life. So check our oil.
    In some cars you typically have replace chain at least once in lifetime of the car.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    While there is no timing belt, the water pump is belt driven.
  7. M in KC
    358
    106
    KC, MO
    ^ True, but it is externally mounted and in today's modern engine compartment it's relatively easy to change. Unlike a chain driven water pump in a 4th gen Maxima which is a chore to change. To the OP, the Pri water pump also has an early warning mechanism built into it to monitor its condition in the form of a weep hole. If you see pink/light pink crusty stuff around your water pump or what looks to be line of discoloration on the passenger side under your hood amongst other things its time to replace the water pump.
    pjrprius likes this.
