Is there a "vent" setting???
Discussion in 'Gen 2 Prius Main Forum' started by curtis0916, Jul 12, 2011.
  1. curtis0916
    curtis0916 Junior Member
    Abilene, KS
    I was wondering if there is a vent setting to just blow air through the cabin or is it required to set a temperature to have the fan blow air?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    MAX COLD for the Iconic (04-09) model.
    LO for the current (10-11) model.
    Both bypass the heat/cool system and just blow air from the outside. And if you also select RECIRC, it will use air from the intead instead.
    2 people like this.
  3. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Also make sure the A/C compressor is turned off. This and the above settings that John mentioned will give you vented air from the outside.
  4. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    there is no max cold on the gen II prius...there is 65 and then LO....neither kick on compressor unless you select A/C....
  5. gdbelden
    gdbelden Gator Hator
    66
    70
    Virginia
    yep, just "de"select A/C then it is just vent, but set temp to lo
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Did they change something I wasn't aware of and am just learning about? In my '04 I go from 65 to max cold. Seriously, it says "MAX COLD"
  7. Politburo
    Politburo Active Member
    971
    208
    My 09 has LO..
  8. LIPriusFreak
    449
    34
    Long Island, NY
    lower than 65 it goes to LO..no MAX COLD here on my 06.....maybe I got screwed or you gave someone "special favors" to get your "special edition"??? :eek: ;)
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The only problem with this whole scenario is the Prius is NOT a balloon! :eek:
    If you want a good flow of outside air you are going to have to open at least 1 window, at least 1/2 inch or better. I usually choose the passenger rear window.
    Try it, the minute you open the window, the air flow will increase quite a bit.
    But then, so will the NOISE, I live with it! :D !
  10. TonyPSchaefer
    14,816
    2,501
    66
    Same here. I normally keep the driver's window up and crack the other three.
  11. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Maybe the names for the settings differ between markets. Mine says 'max cold'.
    I leave the windows down a bit around town, but all the way up on the highway - it's just too noisy otherwise.
  12. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    cant the air get out of the prius via the battery cooling vent? added benefit is airflow over batteries without the battery fan running...
    just a thought.
    although i agree with all of you that to get some decent vent flow cracking a rear window is very beneficial.
    especially with fan on low or off
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    All cars have some built in outflow for venting. Opening windows increases the amount.
    Tom
  14. qbee42
    18,058
    3,081
    Northern Michigan
    If the OP wants venting, they should read Fred's House of Pancakes.
    Tom
