Is there a way to make the interior lights “warmer”?
Discussion in 'Gen 5 Prius Main Forum' started by priusmouse, Oct 4, 2023.
  1. priusmouse
    priusmouse Member
    251
    84
    Long Island, NY
    2023 Prius
    I *finally* received my Gen 5, and my only complaint so far is that the interior light is very cool white.
    not really relaxing at night.
    Is there any way to change the tone to a warmer color? Did other trims or colors have a warmer tone for it?
    I’m starting to understand why the teslas have customizable ambient lighting now..
    mountaineer likes this.
  2. Pulse07
    Pulse07 Active Member
    273
    139
    East Bay, California
    2020 Prius
    XLE AWD-e
    By warmer, I assume you want it to be more "yellow"? I believe you have to change the bulbs. If they are the same and the Gen 4, the Map and dome lights are incandescent bulbs.
  3. Pulse07
    273
    139
    2020 Prius
    XLE AWD-e
  4. Gokhan
    Gokhan Senior Member
    4,665
    1,871
    Paramount CA
    You cannot change the color temperature of a single LED because it is an intrinsic quantum-mechanical property. You would need at least two so that you can superpose them.
    However, you can buy a yellow or blue film and cover the display with it to change the color temperature.
  5. hill
    8,253
    of COURSE you can now days. You can go online or to any AutoZone type retailer and find plenty of listings. The color is referred to as Kelvin. 8,000K is a cool (blue) temperature whereas an LED bulb you're looking for is around 3,000k warm (yellow). We just finished re-lamping our motorhome's fridge, storage & closets' interior lights w/ LED's. Pull the lamp out and take it down to the auto supply and they can match it for you with the color you would like.
    Good luck!
