Is there a way to recalibrate the skid ecu, with techstream?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MP3gee, Nov 9, 2020.
  1. MP3gee
    MP3gee New Member
    Is there a way to recalibrate the skid ecu with a techstream? I seem to see alot of older & some recent post about needing to replace it. But has anyone been successful in just recalibrating or resetting one?
    I am getting C0215, c1242, c1247, c1311, c1313, c1377
  2. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Many will use techstream, doubtful if there are any other options.
    Maybe this post/thread would be helpful : Trouble codes after skid control ECU replacement | PriusChat
    Have you have already been through the step by step workups for the above DTCs ? (C0215, c1242, c1247, c1311, c1313, c1377)
    Please follow up and update in this thread.
    MP3gee and Raytheeagle like this.
  3. MP3gee
    MP3gee New Member
    Ok so the Prius had a bad battery & was throwing all kinds of codes before the replacement. Now it is throwing just 2 abs/vcs/trac codes: C1256, c1345. There is no loud buzzing warning & the brake pedal is firm. Before battery change it was not throwing the C1256.. Why isn't the car setting off a buzzing assuming as most do the abs accumulator is bad? Any tips would be helpful.. Also I tried resetting the codes with no luck.
  4. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Did you click on the small snowflake looking icon to retrieve the 'detailed code' (subcode, INF, or secondary code) ?
    Knowing the subcode(s) can help narrow down the issue and potentially save time, money, and effort in solving the problem
    Here is the workup for DTC C1256 with detailed codes 141 and 143 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21avn/cic12565.pdf
    Here is the workup for DTC C1345 with various detailed codes : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21avn/cic13456.pdf
    Raytheeagle likes this.
  5. MP3gee
    MP3gee New Member
    Thank you, I did check them but didn't think anything of them, will capture them next time around.
